Fuel Pump
My fuel pump seems to be going bad. I recently moved the fuel pump to the front & I used everything (including the pump) from a donor '76 car.
Unfortunately, I know nothing about the fuel pump since it was sitting in the trunk of a 914 that I found in a wrecking yard. (Did I mention that I stripped the car clean & solved all my problems in one weekend! Yea! new mirrors, carpet, sound pad, etc...)
Anyway, I really don't want to spend the $200 for a new pump & I noticed that the 924's & 944's & VW Buses have similar looking fuel pumps - could I just use one of those since I can pick one up for around $10?
Just wondering - I promise to fix it right someday.
Also, for the record - I already changed my filter, tank screen, & injectors.
Thanks............................................ .Vern
Old 07-31-2003, 09:09 PM
914 Geek
If you can work out the mounting issues, get the right-sized fuel lines to and from it, and get the electrical connectors hooked up correctly, sure!
--DD
Old 08-01-2003, 08:51 AM
ErnieDV's Avatar
There is no reason you can't use one that is listed for a VW Bus, but you won't get one for $10. I put one in my '73 2.0L and it cost me $90 for a rebuilt unit. It works great. My son's '75 Bus needs a new pump and I just bought a new MSD pump from Summit Racing for a little less. We'll see how it works out.
Ernie DeVries - Flagstaff, AZ
1973 2.0L FI Daily Driver
Join the AZ 914 mailing list!
I am Mike Müller's evil twin
Old 08-03-2003, 09:46 PM
