JEM JEM is offline
JEM's Avatar
Replacing front motor mounts on 2.0
I need to replace the front motor mounts on my 2.0 engine. Do I have to take all the fan housing off to do this or is there an eaisier way ? The engine is out of the car, I can't see a way to get to the top bolt of the bracket or the nut that holds the mount to the bracket.
Thanks,
Jerry
Old 08-09-2003, 02:16 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
you can do it with the engine in the car and you don't have to remove the fan housing. it's just hard/awkward to get to. may need a stubby 1/4" ratchet to fit in to get to the top nuts. DD says you can remove the oil filter to get some more room. it's not bad, i've done it. you should be able to do a search on the topic as there was a post about replacing motor mounts about 6 mo ( + or - ) ago.
ps: oh yeah, support the engine and drop the support bar to put the new mounts in
whoops, my bad. skipped the part where the engine is out of the car
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 08-09-2003, 04:23 PM
John Rogers's Avatar
Since the engine is out of the car I would pull the fan housing and all the sheet metal stuff and really clean and paint them up nice. It makes it much easier to do the motor mounts at the same time. I did our 1974 a couple of years ago with the engine in the car and it is a pain!!! Good luck.
Old 08-09-2003, 05:55 PM
Zeke's Avatar
Yeh, they're up in there. Good time to check the seal and oil pump.
Old 08-09-2003, 06:04 PM
JEM JEM is offline
JEM's Avatar
Thanks for the help. I may pull the fan housing anyway, it is leaking oil in front, and the tin could use some new paint
Jerry
JM Motorsports
Custom Paint & Bodywork
81 911 SC ,black
73 914 V8 LS1
83 Audi Ur-Quattro,black
Old 08-09-2003, 06:47 PM
check/clean the oil cooler while it's opened up. you will not have a better opportunity. get a new fan belt too. if you have some extra coin replace the seals for the engine tin if they're bad
kevin
here? not so much i think. high five!!!
Old 08-11-2003, 06:30 AM
