Arlen's Avatar
Trans install
Got the new trans in, the bottom nuts are snug--but the bolt I *thought* I pulled from the top side of the tranny that connects to the engine pops in but doesn't catch, it's not long enough...
I must have misplaced the right bolt, maybe I'm using the starter bolt instead of the trans bolt?
Here's my real question--the clutch cable is on, and the clutch throw seems the same as with the old trans, and I didn't have to shim the pinoin bearing? inside the trans (read that somewhere, if the clutch doesn't have enough throw... or... something). I get into the cockpit, and test the shifting between gears. 1st, 3rd, 5th feel real good, feels solid when entering all these gears. But, reverse, 2nd and 4th don't feel solid--they are more *squishy*.
Also, before when shifting to 1st or reverse, the shifter had to be pushed over to the left side--through springy resistance. Now I don't have to do this, it seems as though the gearbox has "lost width", and that springy resistance to get over to those far left gears disappeared...
Any idea why the change?
Old 08-13-2003, 09:11 PM
skline's Avatar
Both top bolts have a nut on the other side on both of my cars. Look for the nut that fits the bolts.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 08-13-2003, 09:19 PM
Arlen's Avatar
I have a '74 engine, and when I pull the top right bolt on the trans, it had no nut.... unless that nut is sitting somewhere in the engine bay now...
Old 08-13-2003, 09:43 PM
canna change law physics
red-beard's Avatar
You need to do a shift linkage adjustment.
See the last page of my Tranny Article...
James
Red-beard for President, 2020
Old 08-13-2003, 11:17 PM
