M. Hendrix's Avatar
Lil stuff
Muffler has a small dent I want out, should I drill it, pull that out, then spot it? Anyone have pics of the inside of a 2.0 muffler?
Heat exchangers are acceptable, but showing signs that the end is nigh, I like heat. Is there a problem with using JBWeld as a filler? It's the little corrosion around the ends of the boxes. I was going to spray those with a rust converter, and then use exhaust paint to seal it up, I guess.
I need wheels so I can pull the fenders out!
Forced vacation stinks.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 08-13-2003, 04:18 PM
DuckRyder's Avatar
Send a message via AIM to DuckRyder
I would take it to a body shop and let them use a stud gun to pull the muffler. If you have to drill it, welding it up is probably the best solution.
Robert
1975 Porsche 914/4-2.0
1972 Ford F100 Ranger XLT
2006 Ducati Sport 1000
323i.net
RangerXLT.com
Old 08-13-2003, 05:16 PM
kellzey's Avatar
I would go see a shrink and get some Paxill. Great for OCD.
Just kidding... I have no idea!
Qarl
Old 08-13-2003, 05:29 PM
M. Hendrix's Avatar
=o0
I can't believe YOU just said that!
M
Old 08-13-2003, 05:45 PM
skline's Avatar
I have one of those stud pullers. It works great. Just spot welds a little pin on and you pull on it with a slide hammer. I used it a lot on my car and it worked so good you cannot even tell where I used it. If there is any rust holes in that muffler, dont use JB weld to fix them. It will probably fall out after awhile. Just weld a small piece of metal over the hole and you will be set.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 08-13-2003, 06:04 PM
M. Hendrix's Avatar
Oh man, I see how that works, I need that.
The muffler is very nice, except for a dent from sitting on a shelf, the HEs are brittleish.
M
Old 08-13-2003, 06:09 PM
canna change law physics
red-beard's Avatar
Miles - YOU are SOOOOOOOO right!
James
but that doesn't make Karl wrong
James
Red-beard for President, 2020
Old 08-13-2003, 06:10 PM
M. Hendrix's Avatar
Well, he's the one that had the lab break down the compounds in the upholstery screws so he could have some made!
M
Old 08-13-2003, 06:13 PM
John Rogers's Avatar
If it were me I would add a similar dent on the other side/end and tell everyone it is a special factory limited edition muffler that was used on noise restricted race tracks in Germany in the early 70's!!!
Old 08-13-2003, 06:30 PM
kellzey's Avatar
Just kidding about the OCD.
This coming from someone replacing nearly EVERYTHING on his 914 at virtually no expense.
Yes... I am an idiot.. any medication for that?
Qarl
Old 08-13-2003, 06:34 PM
M. Hendrix's Avatar
John, I bought it of Ebay listed just as you said.
Karl, you weren't kidding, and neither was I... lmao!
Hope all is well on the homefront.
M
Old 08-13-2003, 06:43 PM
Yes,
Go out into the garage and find something to work on.
Paul
Old 08-13-2003, 06:44 PM
Unregistered
sammyg2's Avatar
Hmmmm, if you play with the timing just right you could backfire you freshly rebuilt motor hard enough to pop that dent right outa there
Old 08-13-2003, 07:45 PM
skline's Avatar
Hey Miles,
You could do like I used to with motorcycle gas tanks, Fill it up with water and cap everything closed and then stick it in the freezer for a few days. The water expands and pushes the metal out. My ex wife used to hate that.
75 Slantnose V8
72 914 Parts car
Old 08-13-2003, 07:51 PM
auh auh is offline
auh's Avatar
Send a message via AIM to auh
What about The Ding King?
Well, it works on tv for Billy Mays
Adam
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 08-13-2003, 08:09 PM
M. Hendrix's Avatar
These are great ideas, I am going to use them all!
My car also has a few dents, I need to find a big freezer.
The ding king works, I beat the hell out of my neighbor's car with one, dings everywhere!
M
Old 08-13-2003, 08:16 PM
Scooter311's Avatar
Hawdy
Have you fixed it yet? More from the motorcycle world - roost dent on my $250 dollar motocross expansion chamber - capped the ends - used propane to heat the dent till it slowly came out.
You need to put a tire valve stem on one of the caps to fill the pipe with a little air, then the expansion pushes the dent out. A trip down the plumbing aisle and about 12 bucks.
Almost magical, astound the wide-eyed onlookers.
- "NOW" Magically Delicious -
Old 08-14-2003, 09:20 AM
Scooter311's Avatar
Oh yeah, don' t try this next one - my old Suzuki 100 had a big dent in the tank, right where the prev owner had smacked into it with his, -ahem- "package". I put a cup of gasoline in it, set it behind a tree, and threw lit matches at it, thinking it would blow up and blow out the dent.
It just burned feebly. Thank god. I was 12. It was a big tree.
Old 08-14-2003, 09:29 AM
red-beard's Avatar
Hmmmm - Early Darwin award pre-qualifying rounds...
James
Old 08-14-2003, 09:54 AM
"You could do like I used to with motorcycle gas tanks, Fill it up with water and cap everything closed and then stick it in the freezer for a few days. The water expands and pushes the metal out."
I had a small 8 ounce metal pocket flask that got dented. Just a single dent that looked like it would pop out if you could get to the inside. I had a brainstorm - air pressure!. I closed it with its cap and dropped it into a pot of boiling water and waited for the heat to expand the air and pop out the dent. Got distracted, Oh s***! At least no explosion. Found the the sides of the flask had bowed completely out. Looked like a distorted bloated canteen. Toss one flask.
I should have used the feezing water method.
Mike
Old 08-14-2003, 10:44 AM
