Question about leaky flywheel seal
Installed my fresh 2.0 which had been sitting since overhaul in 1984. After 300 miles only apparent problem was a substantial leak from the flywheel seal. Pulled tranny and replaced seal, flywheel o-ring and clutch disc (may not have been necessary but wanted 6 spring disc). Took first drive today and it is still leaking. Not as bad as before, but it leaks! Any ideas? Do seals need to "break in"? Do I just live with it until clutch gets oily?
Old 08-17-2003, 12:00 PM
M. Hendrix's Avatar
I have no experience with that, but I can't recall a break in period on that seal.. I am pretty sure you knew that.
I don't know what goo is applied to install that seal, did you use any? Maybe someone can chime in on that.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 08-17-2003, 02:25 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
are you sure it's the seal and not the oil galley plugs?
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 08-17-2003, 02:38 PM
galley plugs were dry, threaded allen head type done at time of the overhaul.
Old 08-17-2003, 03:44 PM
914 Geek
Did you make sure that the lip on the flywheel where the seal rides was not worn? If it was, you will have to push the seal in further to ride on a non-worn area.
Not sure what else it could be offhand.
--DD
Old 08-17-2003, 07:56 PM
canna change law physics
red-beard's Avatar
Just replaced the seal on the 6. The seal that was in there seemed to be an aftermarket beige Japanese job that, when compared with the German pink seemed a little different in the dimensions. Not a lot, but a little.
I'll tell you next week if it leaks.
James
James
Red-beard for President, 2020
Old 08-17-2003, 09:41 PM
Didn't carefully examine the new seal. It was kind of a red/brown color. Source was impeccable.
Old 08-17-2003, 09:45 PM
Is it leaking trans fluid or engine oil? I think you know where I am going with this.
CCL
Craig C. Laughlin CAMP 914
Helping to bring your 914 into the 21st century.
http://www.camp914.com
Old 08-17-2003, 09:46 PM
Craig, you gotta work on your reading skills. I said oil from the flywheel seal, not from the transmission.
Old 08-17-2003, 09:48 PM
red-beard's Avatar
Yeah the new seal I have it an orangy-red.
James
Old 08-17-2003, 09:51 PM
So it is leaking engine oil.
Correct.
CCL
Old 08-17-2003, 09:54 PM
That's what I said, but you can do a taste test any time!
Old 08-17-2003, 09:55 PM
Okay,Chef Chambers.
CCL
Old 08-17-2003, 09:57 PM
