spring rate identification
how do you identify what rate a pair of springs are?
the only identification i can find is two lines stamped on the top. thanks |
Sometimes you can tell by color but I am not sure what color is what. Mine are 165 pound and they are blue and Joes are 165 pound progressive and his are red. I saw some yellow ones that were 180 pound. I dont know if this denotes the spring rate though. If the 2 lines are green then I would say they were factory springs 100 pound?
http://www.pelicanparts.com/gallery/skline It's easier to get forgiveness than it is to get permission. 75 Slantnose V8 03 S-10 Extended cab stepside in Yellow 72 914 Parts car |
914 Geek
If you can mesure the thickness of the wire, and the diameter of the coils, there are formulas that let you calculate at least an approximation.
Or you can use your weight set and a ruler. (And a friend.) Measure the height of the spring with no weight on it. Put the bar of your weight set through the middle (or a broom handle, or ...) and put 50 lbs of weight on the bar so that it rests on the top of the spring. Measure the spring height. (The bar is there to keep the spring upright and keep the weight from sliding off.) Spring rating is in lbs/in. Find the amount that the spring got shorter when you put the weight on it, and divide 50 by that number. Repeat with more weights--the more measurements you take the more the errors will average out. Multiple measurements will also tell you if you have a progressive-rate spring. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Hey Dave, is there anything that you dont know? You always seem to have the answers. I am jealous.
