compufire - tach does not work
I installed a Compufire module and now my factory tach does not work. I tried another factory tach that I had and it does not work either. I hooked up an aftermarket Sun tach and it works. As far as I know, both tachs work. Any clues?
Old 08-25-2003, 07:32 AM
John Rogers's Avatar
When you hooked up the Sun tach, was it at the connections at the dash or at the coil? The tach is fed by the black & purple wire at the coil so you will need to make sure the wire to spade lug connection is good and on the correct coil terminal. We have a Compufire module on our 1974 had have never had tach problems with it. Good luck
Old 08-25-2003, 11:26 AM
Using the same wiring point at the dash. I have taken a tach and hooked up directly at the coil to try it there. Maybe I just had bad luck with 2 tachs at one time and need to get them checked.
Old 08-25-2003, 12:21 PM
I ran into the same problem when I installed my Crane XR-700 unit (I know that it's not the same unit). Couldn't even get an rpm reading with my dwell/tach meter, which worked fine with the standard points/condesor setup and on my wife's minivan.
Wish that I could be more helpful, but after following the Crane tech support tips, my tach still wasn't working. Eventually, i jazzed up the shutter disc and put the points/condensor back in until I have more time to find a solution.
You may want to contact the tech support people at Compufire to see if they can give you some suggestions. I know that Crane sells a tach adapter device which can be used when all else fails. If you run out of other options, Compufire may have a similar "solution"
Best of luck.
Howard
1974 914 2.0 "pearl" white
Every so often, I even get to drive it!
Old 08-25-2003, 07:58 PM
kellzey's Avatar
The older tachs tend to not like the type of signal from the newer electronic ignitions.
Solutions are
1. To get a tach amplifier
2. Replace the internals on your tach to accept the new signal from the newer ignition. (this is what I did on my gauges)
3. Get an adapter to convert the new signal to the older type signal.
Call Compufire and see what they say.
Qarl
Old 08-25-2003, 08:43 PM
