415pb's Avatar
Compression Test...Can someone tell me what's next...
I did a compression test on my 914 2.0 D-Jet. I received the following readings:
Cylinder #1: 145
Cylinder #2: 145
Cylinder #3: 100
Cylinder #4: 160
I did the test with all spark plugs pulled, coil wire pulled and at full throttle. I would appreciate any advice on what to do next. I know #3 is pretty low. Should I start getting ready for a rebuild and what should I rebuild? Again any advice is greatly appreciated.
Thanks,
Rod
________________________________
1974 914 2.0 D-Jet
Old 09-04-2003, 08:33 PM
Banned
Alfred1's Avatar
The Haynes manual says that the maximum permissible difference between cylinders is 21 lb/in^2 so you do seem to have a problem. A leak-down test will give you a much better idea of what the problem is. You can find more info here .
Old 09-04-2003, 08:53 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Try adjusting the valves and re test first. Sounds like a tight valve to me.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 09-04-2003, 09:31 PM
DuckRyder's Avatar
Send a message via AIM to DuckRyder
You can diagnose valves vs rings by re doing the test "wet". To do a wet test you add a few drops of oil and retest.
if they come up much it is rings, if not valves.
Robert
1975 Porsche 914/4-2.0
1972 Ford F100 Ranger XLT
2006 Ducati Sport 1000
323i.net
RangerXLT.com
Old 09-05-2003, 05:23 AM
415pb's Avatar
I adjusted all the valves to spec before the test. If I did have a tight valve, would it be cylinder 3 or 4? I will also try to re-test with oil. Thanks again for the help...
Old 09-05-2003, 06:05 AM
Bleyseng's Avatar
It would be #3 since that's the low cylinder.
Try the wet test to eliminate the possiblity of a cracked ring or scoring of the cylinder wall. My guess is a valve that is burnt from being too tight.
Geoff
www.914Club.com
My Gallery Page
Old 09-05-2003, 08:34 AM
415pb's Avatar
Geoff, what am I looking for when I do the wet test. When I put a teaspoon of oil through the spark plug hole, what do I do next...Sorry but I am new to this. Again thanks...
Rod
Old 09-05-2003, 10:10 AM
John Rogers's Avatar
You should make sure the engine has warmed up fully if possible before you do the compression test too. Do a "before adding oil" compression test and be sure to count the jumps the gauge takes to top out. Then add the shot of oil and test each cylinder again. If the low one has jumped up then it is probably the rings that are worn and the oil has sealed them some. I agree with the previious post about making sure the valve adjustment is right on spec before you do the testing and insure the batt is fully charged. Good luck
Old 09-05-2003, 10:18 AM
415pb's Avatar
Okay, just did the test wet. After doing a dry test, cylinder #3 was still at 100. I then squirted some oil into the cylinder and at first it jumped up to 105. I then tried the test again and squirted some oil into #3 again and it jumped up to 125 and held there. Is this bad? Is it time to rebuild? Thanks for the help guys, I really appreciate it.
Rod
Old 09-05-2003, 05:34 PM
DuckRyder's Avatar
Porsche Crest
I'd say that is a ring problem.
It is harder to do a wet test on a flat type of engine, it probably took the second shot and a few spins to distribute the oil fairly evenly. It's still a bit low thhough.
If it runs well otherwise, you could probably just replace the P/C's and inspect / grind the valves. You might even get away with just rings / gaskets.
I have this bad habit of letting stuff snowball though, so I'd go through the whole thing.
Robert
323i.net
RangerXLT.com
Old 09-05-2003, 06:26 PM
Bleyseng's Avatar
What does the plug look like? If its all oily and black then maybe I would say the rings are bad in that cylinder. Maybe the cylinder walls are scored?
Hmmm, worth taking a look at before something really bad happens.
www.914Club.com
My Gallery Page
Old 09-05-2003, 07:32 PM
415pb's Avatar
I changed the plugs about three months ago and they look fine.............I know the pics are probably overkill, but I'm trying to explain this stuff as best I can. Thanks for all your help..
Thanks again
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-05-2003, 07:53 PM
grind weld build
sean_V8_914's Avatar
re-ring. check end play on teh crank to determine condition of bottom end.
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 09-05-2003, 08:41 PM
canna change law physics
red-beard's Avatar
Leakdown test anyone?
James
Red-beard for President, 2020
Old 09-06-2003, 04:44 AM
Bleyseng's Avatar
Next thing, junk the platinums! Use the regular plugs or copper cores instead of those things.
I'd go the leakdown test next.
Geoff
www.914Club.com
My Gallery Page
Old 09-06-2003, 06:57 AM
415pb's Avatar
Sounds like I'll be doing the leak down test next. Can you guys let me know how. I've heard you can put together your own, is this true? Thanks again............
Oh, I forgot, I'll trash the platinums...Your like the third person to tell me that, so out they go.....
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-06-2003, 07:19 AM
Kenny Powell's Avatar
I'll be the 4th............get rid of the platinum plugs,they don't work well in our engines............get the Super Bosch they work better!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 09-06-2003, 08:17 AM
Unregistered
sammyg2's Avatar
Set that piston at TDC, put it in 5th gear with the parking brake on and wheels chocked.
Pull the valve cover off of that side.
Hook up a pressurized air source through the spark plug hole and put air pressure on that cylinder.
Listen for the air leak. If it is going out the exhaust pipe you have a bad exhaust valve. If it leaks out the intake, bad intake valve. if it blows out from the crankcase breather, bad rings. If it blows out the head where the valve cover normally is, it's leaking valve guides.
A little leakage into the crankcase is normal, but a lot is not normal.
Old 09-06-2003, 09:14 AM
red-beard's Avatar
DIY Leak Down tester
I bought one from these guys:
https://www.carshopinc.com/
But the site seems to be down right this second.
$53
James
James
Old 09-06-2003, 09:16 AM
415pb's Avatar
You guys are great, thanks for the help and I'll give it a try...
Rod
1974 914 2.0 D-Jet
2004 BMW R1150RT-P
Old 09-06-2003, 11:25 AM
