cruiksdr's Avatar
Question Anybody ever try machining rear hubs?
More specifically, for the five lug conversion, has anyone ever tried machining the splines on the 914 stub axle to fit the 911 rear hub?
I've got the complete rear running gear (hubs, rotors and calipers) from a 911 that I'd like to use. I like the hub because it is nice and heavy duty, but of course, the stub axle won't work. Seems like it would be possible to have the 914 machined to mate with the 911 -- or am I completely insane??
Thanks!
Daniel
PS: thanks to all those who helped me out over the weekend regarding bearing removal. What I learded... There's so much history here, I need to remember to search on the question first. Lots of wisdome and experience out there
'73 914-6 3.0SC
'69 Jaguar XKE
'05 Colorado Crew Cab
Old 09-08-2003, 06:54 PM
Ron Meier's Avatar
The splines would be more correctly "hobbed" not machined.
So, have a machinist cut you some axle shafts and have each end splined for the cv joint you want to use.
Or use the 911 hubs in the 914 trailing arm. Believe the bearing ID is the same and the axle a little shorter so you have to have a 1/2" spacer machined for the inboard cv joint.
"Inventor - Blue Flame 914 Seat Heater"
"Yellow Rusty Cars Are Faster"
_____________________________
'70 2.5 (I'll never finish it - Somewhere over the rainbow.....,)
'73 2.0 (Just Not The Same)
'74 2.0 (Heartless & Lungless)
Old 09-08-2003, 08:44 PM
Why go to all that trouble? Get 944 turbo stub axles and CV joints. Make usre that you get the ones from the 944 with the aluminum trailing arm. The stub axles fit an early 911 (i.e. 914/6) hub, and the CV joint is splined the same as a 914/4 axle. It's a true bolt together, and you get a bigger, heavier duty outboard CV joint. If you want a bigger inboard joint too, find the transmission drive flanges from a 75 911 with a 915 transmission. They will bolt into the 914 transmission, and they have the same size and 6 bolt pattern as the 944 turbo CV joint. And don't forget the gasked for the 911 transmission flange when assembling.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 09-09-2003, 05:45 AM
Unregistered
sammyg2's Avatar
Clay, now that is some good information. Gonna file that one away for future reference. Thanks.
Old 09-09-2003, 09:46 AM
M. Hendrix's Avatar
Rockin' Clay!
That is good to know, you can but a whole 944 Turbo for less than the price of stub axles.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 09-09-2003, 05:11 PM
