Banned
Alfred1's Avatar
Couple of questions about calculating compression ratio.
For those of you who have done this, did you use some kind of special tool like this ? I have a book about engine blueprinting that says you should take the compressed head gasket thickness into account when calculating the compression ratio (first photo below) but all of the formulas that I have seen for calculating an air-cooled VW's c/r (second photo) only take cylinder volume, deck clearance volume and combustion chamber volume into account and disregard the thickness of the compressed shim between the barrel and head. Is the thickness of this shim insignificant?
Old 10-04-2003, 08:48 PM
woodman's Avatar
Good your looking this close at what you're doing. Porsche issued a tech bulletin recommending not using the head gasket. http://www.dolphinsci.com/techbull.html
Don't account for it in your measurments. Lap each cylinder to it's respective head to de glaze, if you've recently had head work done or had any material taken off the barrel.
'75 1.8 -->1911
Old 10-04-2003, 09:14 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
http://www.aircooled.net/gnrlsite/resource/specgeninfo/calcs.htm
Old 10-04-2003, 09:57 PM
914 Geek
If you do use a head gasket of any kind, you can fold that into the deck height measurement pretty easily... Just add the thickness of the (compressed) gasket to the deck height. That will account for the gasket, though there will be a very small error induced because the ID of the gasket is usually a tiny bit smaller than the ID of the cylinder.
--DD
Old 10-06-2003, 09:43 AM
