Hi All,
Not to sound too idiotic but, what is the purpose of the taco plate? Thanx,
www.pelicanparts.com/gallery/d7n7master |
914 Geek
To keep the oil from falling out of that ~3" diameter hole in the bottom of the motor?
To cover up an inspection hole? (That may have been used on the Bus or another Type IV application...) To provide a place to mount the oil temp sender? Other? --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Gas
That location was used for a slip in crankcase heater for super cold climates..........the heater slid inside the case@! I have never seen one up close!
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
(Jake) Now that's strange...an oil filled heater? Just kiddin'. I have one in the house, - not in the car, but those Germans'!!! Will the gasket for the oil sump fit at the taco plate location? Or do I need to buy a different gasket? Thanks
It's diifferent. It's actually a big o-ring. Don't over tighten the bolts to the plate. It will bend.
Oh great. Does this O'ring have part#? HELP!!!
021 101 269 A
That's a guess.
Jeff Keyzer 72 914 w/2056 built by Mark DeBernardi @ Original Customs Megasquirt with MSII upgrade |
Thanks everybody. I just ordered 2 from PP. I need to install a oil temp sender so I thought I'd better have a new seal.
Installed the new seal & new oil temp sender. Routed new wire from sender to temp guage. Works GREAT!!! Thanks everybody!!! Piece 'O Cake.
Does someone has a pic of that heating device?
'74 Porsche 914 2.0l '90 VW Vanagon 1.7l Diesel |
You need an
O-ring - 021 101 269 A 2 copper washers - N 013 803 2 1 gasket - 039 101 287 Ken
Anything worth doing is worth doing in excess Every silver lining has a cloud Assume Nothing |
What's the gasket 4? Between the plates?
Yes & the copper washers seal the screws.
Ken
