The rear is too soft. Get rid of the Progressive springs. The 180's, if they have tighter coils on one end are progressive also. Not much more i can tell you.
My set up is 22mm torsion bars, 22mm sway bar set semi-loose, and 200# rear springs. 15x7 wheels with VRacers. Stays flat. Sometimes, depending on the speed of the corner and how tight it is, a wheel might lift a bit, but not much. pretty hard to eliminate that with out going way stiff on the front bar or more rear spring. Your progressive springs are not 165# all the time. My guess is that on turns where the weight of the car is not causing the springs to compress to the full 165#, is making your car handle like it has soft rear springs, and the front bar is stiff enuff to lif tthe front wheel. Maybe the non progressive 140# would be better...?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
JPIII Early Boxster |
Hey, I resemble that remark
IMO, when you reach a certain level of tire grip, you start waving to the fans. The best cure is stiffer springs at both ends. Stiffening one end without doing the other will lead to over/understeer, depending which end gets stiffened. The front AR bar won't be able to compensate if the F/R spring rates are too far off. For instance, stock t-bars & 200 lb rears will have the back ahead of the front on a regular basis.
![]() I use 21mm t bars & 200 lb rear springs. The front A/R bar is set a bit towards soft. It pushes in the tight stuff (AX tight), but is neutral in the medium speed stuff....oversteers a bit in the sweepers. It'll do for now.
JP and Chris are right as to keep a corner down you have to push up from the diagonal corner. Of course you could soften the front way up and corner on TWO wheels instead of three, but that can get a little hairy!!
Adding a "stock" rear sway bar stopped my wheel lift.
Set-up: 22mm Front torsion, 22mm Front Sway(set full loose), 180# rear springs. Had lots of wheel lift before I added a stock rear bar. Ken
Anything worth doing is worth doing in excess Every silver lining has a cloud Assume Nothing |
If you're not going to spend money, then loosen the front
bar to get the wheel back down. Everybody's right that this will change your over/understeer. I run 21mm torsion bars, small weltmeister front bar almost full loose, 180 springs, and it will not oversteer below about 50mph. Mark S. '70 914-6 |
Everybody here in No. Cal. is running 22 & 22 up front.
You can get a used stock sway bar with links and mounting brackets(used - cut off - chassis but cleanupable) from Spencer at EASY in Emeryville, CA. The brackets can be bolted on - no need to weld them - just takes a couple of holes and a 1" hole saw to bolt them on. Ken
914 Geek
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
