canna change law physics
red-beard's Avatar
Cool Blondie's back!!!
I just picked up the Blond's engine, and boy was it heavy....
Wow! It looks so pretty! Nikasil cylinder's nestled between aluminum heads and magnesium case.
Basic things done:
Replaced crank and rods with 2.7 crank and rods (Stroked)
Upgraded the 2.2T P&Cs to 2.7 RS P&Cs
Upgraded the T cams to S cams
Piston squirters installed
heads redone, new valves and valve guides
Heads ported
Intake manifold ported
Casesavers installed
With the carbs setup right, this engine should put out 210 hp, up from the 140 hp is was previously producing.
Now where was that limited slip differential.......
James
James
Red-beard for President, 2020
Old 10-06-2003, 04:01 PM
Toast's Avatar
Look forward to seeing Her again!
73 Yellow 2.0
86 Toyota 4X4
Old 10-06-2003, 05:01 PM
M. Hendrix's Avatar
oh my gord! congrats man!
m
-what are YOU doing later?-
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 10-06-2003, 05:09 PM
Toast's Avatar
M,
Changing my dress color.
73 Yellow 2.0
86 Toyota 4X4
Old 10-06-2003, 05:17 PM
Toast's Avatar
Ahhh, much better. Hope it doesn't get wrinkled in the 914.
73 Yellow 2.0
86 Toyota 4X4
Old 10-06-2003, 05:20 PM
red-beard's Avatar
Blond's New Heart
mmmmmmmmmmmmmmmmmmmmm Horsepower
James
Old 10-06-2003, 08:33 PM
skline's Avatar
Is that the crankshaft next to it? How is it going to run without that? It sure looks pretty.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 10-06-2003, 08:45 PM
M. Hendrix's Avatar
That's nice Toast.....
WOW JAMES!!!! THAT LOOKS INCREDIBLE!!! NICE MAN!! HOLY COW!!!! I CAN'T BELIEVE HOW NICE THAT LOOKS!
M
Old 10-06-2003, 08:46 PM
red-beard's Avatar
Fortunately, that is the old crank. Coming to an Ebay auction soon.
Yep. It just needs a little sheetmetal, a couple of carbs, oil cooler, oil lines, generator and distributor....
Really won't take to long to put it back together.
James
James
Old 10-06-2003, 08:54 PM
M. Hendrix's Avatar
James
Hello? (tapping) Is this thing on?
GO DO IT.
M
Old 10-06-2003, 09:11 PM
jkeyzer's Avatar
Wow, that looks nice and shiny. I want one.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 10-06-2003, 09:35 PM
hardflex's Avatar
who did the work for you, and how much $?
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 10-06-2003, 10:57 PM
red-beard's Avatar
Motorwerks in Downtown San Diego.
Costs: for EVERYTHING, about $6000.
It was about $2700 in Labor and $3300 in materials. P&C's were only $1700 (RS Spec 2.7) Brand new Factory Original cam shafts $595. OEM valves $320.
The Heads received a lot of work. Case had to be machined to take the larger cylinders. Piston Squirters installed. Most of the threaded holes changes to case savers.
Basically, we did the right things to strengthen the case, and make it breathe.
James
James
Old 10-07-2003, 05:31 AM
John Rogers's Avatar
It looks like you made it to TJ to get the work started on the car?? I was off racing when you called my office so that is why I never got back to you.. Nice picture and I was wondering if the carbs are going to be overhauled too?
Old 10-07-2003, 06:15 AM
red-beard's Avatar
Carbs are a question mark. The cost of re-jetting, etc, I may be better off selling my carbs on ebay and buying a set of PMO's
Seriously considering this!
James
James
Old 10-07-2003, 09:20 AM
Mr9146's Avatar
I hear the MFI gods calling ...
Old 10-07-2003, 09:46 AM
914 Geek
I don't. PITA to fit the pump correctly on an engine that didn't come with it originally. The left side cam blanks are different, the left cam tower is different, plus the anciliary stuff....
Plus getting a system that's in good shape will likely cost more than a set of PMOs.
--DD
Old 10-07-2003, 11:37 AM
Mr9146's Avatar
Dave, that's because your ears aren't tuned correctly
Hey, Red Beard, RS-spec includes MFI
Come on!! You know you wanna come over to the dark side
Old 10-07-2003, 11:54 AM
jkeyzer's Avatar
To run MFI he'd need to have the right MFI cam on one side with drive pulley installed. That kind of thing needs to be thought of BEFORE the engine rebuild.
Also getting to the adjustments would be a pain, and good luck finding a mechanic who knows anything about tuning MFI and is willing to work on it in a 914!
Jeff Keyzer
Old 10-07-2003, 12:07 PM
Mr9146's Avatar
If I'm not mistaken - which I might be - the left side S cam should come with the threads for an MFI pulley ... if the cams are factory between 69-72 or 3. All that's needed from there is the removal of the left side cam-tower plug and the installation of the pulley. You also have to cut out part of the rear sheetmetal for the pump belt ... but it's all worthwhile.
And speaking from personal experience, the only time adjustments are a pain is when you've gotta make 'em. If you do it right the first time, MFI is ultimately trouble free.
To boot, considering my dad's an MFI guru and I own a 914-6 with MFI, I don't think he would be opposed to working on Red Beard's car for him
Come to the dark side ... you are powerless against the forces of the dark side
Old 10-07-2003, 12:29 PM
