D7N7MASTER's Avatar
Question Taco Plate
Hi All,
Not to sound too idiotic but, what is the purpose of the taco plate? Thanx,
www.pelicanparts.com/gallery/d7n7master
Old 10-06-2003, 10:23 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
To keep the oil from falling out of that ~3" diameter hole in the bottom of the motor?
To cover up an inspection hole? (That may have been used on the Bus or another Type IV application...)
To provide a place to mount the oil temp sender?
Other?
--DD
Old 10-06-2003, 10:25 AM
Gas
Old 10-06-2003, 10:26 AM
That location was used for a slip in crankcase heater for super cold climates..........the heater slid inside the case@! I have never seen one up close!
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 10-06-2003, 02:41 PM
D7N7MASTER's Avatar
(Jake) Now that's strange...an oil filled heater? Just kiddin'. I have one in the house, - not in the car, but those Germans'!!! Will the gasket for the oil sump fit at the taco plate location? Or do I need to buy a different gasket? Thanks
Old 10-06-2003, 04:45 PM
Zeke's Avatar
It's diifferent. It's actually a big o-ring. Don't over tighten the bolts to the plate. It will bend.
Old 10-06-2003, 05:31 PM
D7N7MASTER's Avatar
Oh great. Does this O'ring have part#? HELP!!!
Old 10-06-2003, 06:25 PM
jkeyzer's Avatar
021 101 269 A
That's a guess.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 10-06-2003, 06:58 PM
D7N7MASTER's Avatar
Thanks everybody. I just ordered 2 from PP. I need to install a oil temp sender so I thought I'd better have a new seal.
Old 10-06-2003, 07:27 PM
D7N7MASTER's Avatar
Installed the new seal & new oil temp sender. Routed new wire from sender to temp guage. Works GREAT!!! Thanks everybody!!! Piece 'O Cake.
Old 10-13-2003, 06:36 AM
yoh!!!'s Avatar
Does someone has a pic of that heating device?
'74 Porsche 914 2.0l
'90 VW Vanagon 1.7l Diesel
Old 10-13-2003, 06:52 AM
You need an
O-ring - 021 101 269 A
2 copper washers - N 013 803 2
1 gasket - 039 101 287
Ken
Anything worth doing is worth doing in excess
Every silver lining has a cloud
Assume Nothing
Old 10-13-2003, 07:17 AM
D7N7MASTER's Avatar
What's the gasket 4? Between the plates?
Old 10-14-2003, 04:08 PM
Yes & the copper washers seal the screws.
Ken
Assume Nothing
Old 10-14-2003, 07:14 PM
