Biggy72's Avatar
Pearl's havin a brain fart....
well everything's been runnin good. I even got her to quit smokin this past weekend, but today I went to go start her up after work, and there wasn't a fuel pump noise and she didn't want to start. I got out the tester and the fuel pump's not gettin any juice. The fuses are all good. So where else should I check?
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 10-14-2003, 07:46 PM
RustyWa's Avatar
Check out Brad Anders' Fuel Pump flow chart. Works real well.
http://members.rennlist.com/pbanders/FPChecklist_frame.htm
Eric
'75 914 2.0L - Sold!
Old 10-14-2003, 09:14 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Try unplugging the Aux Air Valve and see if you get current to the pump, if so, you need to replace the AAR.
Old 10-15-2003, 08:34 AM
Biggy72's Avatar
where's that at?
Black 72 1.7 914
WSU Formula SAE
Old 10-15-2003, 11:57 AM
Number 30 is the AAR. Try unplugging it. It shares the same circuit path as the fuel pump if the AAR fails, it will short out the fuel pump as well.
Old 10-15-2003, 12:03 PM
RETIRED
Joe Bob's Avatar
Could also be a bad relay in the circuit board.
2012 ML350 3.0 Turbo Diesel
Old 10-15-2003, 01:00 PM
check the pump power connection to the coil.
I had this same problem about 5 weeks ago - found it popped off the terminal at the coil - don't know how it slipped off, but as soon as I reattached it, everyhing was fine.
I'd rather have a bottle-in-front-of-me than a frontal lobotomy.
Old 10-15-2003, 01:49 PM
914 Geek
There is no pump power connection on the coil of any stock 914. If yours has one, it has been modified from stock.
I recall yours is carbureted? So it doesn't have much to do with the D-jetronic FI that we're talking about...
--DD
Old 10-15-2003, 02:20 PM
Bruce Allert's Avatar
Dave... you continue to amaze me. To know Robs car in Texas is carburated.....
Good magic trick man
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Gotta mow the Lawn...
Old 10-15-2003, 04:16 PM
Biggy72's Avatar
not to stroke your ego or anything but you nailed it right on the head jared. It starts now without the aar, but is it ok to drive home? It's like 10 minutes away right now and where can I get a new aar valve?
Black 72 1.7 914
WSU Formula SAE
Old 10-15-2003, 05:59 PM
Biggy72's Avatar
in other words can I get it at my flaps?
Black 72 1.7 914
WSU Formula SAE
Old 10-15-2003, 06:01 PM
Nope Biggy the FLAPS ain't got'm. I'm going by what the Pelican catalog is saying that they ain't available no mo. Try to find one from a friend or wrecking yard that has some 914's. You won't need it until it gets below 45 degrees up there in Raymond. I can take a look on the 1.7 I have sittin' on the floor & see if there's one on it. If so I'll check it out & see if it works.
You can drive without it.......
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 10-15-2003, 08:03 PM
Well.... guess what? I had one aaaaaaaaand it works!
It's yours if you want it for that shiney nice wheel yer show'n on yer picture web site
Not really You kin have it fer the cost of the shipping.
Also, here's a link to a post about cleaning them.
D-Jet Aux Air Valve repair is easy
It took about 15 minutes for it to fully close so it may need some carb cleaner sprayed in it just to loosen it up a bit.
have fun....... & send yer address if ya want it.
bruce
Sit'n here
Hav'n a beer.
Punkin's gone
(sniff)
Old 10-15-2003, 10:13 PM
914 Geek
The wire that plugs in powers a heating element that closes the valve after ~5-10 minutes. It will close after ~15-20 on its own just from the heat of the engine.
You can remove it, pry open the lip of the "can" that is crimped around the lid, and check inside there. There should be a coil of "resistance wire" down at the bottom; it may have shorted to the "can" or the wire going through the bottom of the can may have worn through its insulation. (Hmm, you can check that second option out before opening up the can!!)
If the resistance wire is broken or otherwise needs replacement, you can substitute enough 1-amp resistors to toal 13 ohms of resistance. A 12 ohm "bathtub" resistor will probably work if it fits. Connect one end of the resistor to the wire coming through the base of the can, connect the other end to the can so that it has a good electrical connection.
While you're in there, clean and lube the rotary valve.
Then put it back together again and push the crimped edge of the can back over the edges of the lid. You can seal with RTV or your favorite sealant, but I don't think vacuum gets into the can--just the upper part of the valve.
...Of course, if it's just that the wire into the bottom has worn off its insulation, some electrical tape can probably fix that....
--DD
Old 10-16-2003, 09:41 AM
Biggy72's Avatar
I'll check it out when I get it home tonight. Thanks for all the help.
Derek
Black 72 1.7 914
WSU Formula SAE
Old 10-16-2003, 12:39 PM
Biggy72's Avatar
oh and I pmed you bruce
Black 72 1.7 914
WSU Formula SAE
Old 10-16-2003, 12:42 PM
