Fuch offset and tire size
Like most "teeners" I'd like to see the fattest tires possible on my car without modifying my wheel wells. After reading several posts, I understand that tire clearances will vary depending on tire size and rim offset. The optimum combination appears to be a 205/60-15's mounted on factory Fuchs. I have a set of American Eagle "fake Fuchs". They have a "back spacing" (distamce from of rim's inboard tire bead to rim's mounting surface) of 4 ¾". How does this compare to factory Fuch back spacing?
Also are there any recommendations on 205/60-15's tire brands?
Gary
'85 Targa (fastest), '74 914 2.0 (funest), '71 VW Westfalia (slowest), '16 Q70L (wife's), '17 Armada (daily driver)
Old 10-16-2003, 10:38 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
OEM Fuchs have a 4 7/8ths backset so they should work with the 195x60's
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 10-16-2003, 12:21 PM
914 Geek
205s are hit-or-miss anyway, regardless of which wheel you have. Thankfully, on most 914s they miss... the fenders. (I.e., they fit on most 914s using stock wheels, but not on a few.) You've at least got a decent chance with those fake Fuchs.
--DD
Old 10-16-2003, 01:24 PM
This tire has good reviews:
http://tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+RE950
survey: http://tirerack.com/tires/surveyresults/hpas.jsp
I'm thinking of getting those.
Old 10-17-2003, 03:06 AM
D7N7MASTER's Avatar
Lightbulb
Just clean up those fake fuchs and drop them off at my house. Then you can buy the real thing!!!
...just tryin' to help.
www.pelicanparts.com/gallery/d7n7master
Old 10-17-2003, 07:55 AM
I had 195/60/15's on the back of my '75. They were on fake Empi's . They fit with no problem. I recently changed these tires with the same size, but with a different brand and they "hit" hard. I think I will grind the horizontal lip away a bit. Pete
Old 10-19-2003, 05:18 PM
jnp914's Avatar
Pete,
Names, man.
What brand were those that fit?
Jerry Phillips
'76 912E
Old 10-20-2003, 09:55 AM
