froggy's Avatar
High Beams
Hi, I've got more problems!
the blue light on the tach stays on all the time and I have no High beams when I pull the arm? what the!
"when I become president I will make all the straight roads curvy."
1970 1.7
2001 4.0 Ford Ranger for backup only.
Old 10-23-2003, 02:35 PM
SGB SGB is offline
SGB's Avatar
The wire from the high beam bulb is attached at wrong fuse tab. It should be on fuse one, that has the solid white wire going to left high beam. I think it is a white wire with blue stripe, but you should check the wiring diagrams here at PP.
-Scott
My gallery page
Old 10-23-2003, 02:59 PM
Or ... maybe your dimmer relay is stuck or dimmer switch bad and you have high beams on all the time. One way to tell - if your fog lights don't come on then you're always on high beams. The fog light relay is tied to the same fuse #1 as the indicator light, but on the other side of the fuse. If they do come on then it's something else.
Old 10-23-2003, 03:37 PM
froggy's Avatar
I think high beams are on all the time what should I do
1970 1.7
Old 10-23-2003, 03:55 PM
I'd go after the dimmer relay first - swap it out with one of the other relays and then see if it works. If it still doesn't work, then a bad connection from the relay to the switch or the switch is bad. Here's where a voltmeter comes in handy.
Old 10-23-2003, 03:58 PM
froggy's Avatar
I am an idiot when it comes to a voltmeter, I just figured out how to check the battery for volt. reading. Wiring is my weakness among others.
froggy
1970 1.7
Old 10-23-2003, 04:26 PM
froggy's Avatar
guy,
i wonder if you have looked at my other posting on 12 wire harness confussion
1970 1.7
Old 10-23-2003, 04:28 PM
I once had a problem with the high beam light staying on. And, when I flashed between low & high, it didn't seem like there was much change.
My lights were working perfectly until I installed Euro turn signals. It turned out that my original fron blinkers were not wired correctly and when I put in the extra bulb for the euro conversion - everything went wrong.
So, get out your haynes book & start checking everything from the front bulbs to the fuse box. Chances are, you've got a wire attached incorrectly - somewhere..............................Vern
Old 10-23-2003, 06:49 PM
froggy's Avatar
tidybuoy,
what do you mean by... (Yes! I won it in a raffle)
You live in fresno, 29 miles away cool. thanks for your input.
I am check all over for this wiring ghost. thanks
jeremy
1970 1.7
Old 10-24-2003, 09:15 AM
I won my 2nd 914 in a raffle - only $25 bucks. I'm having it shipped from West Virginia & is't supposed to be her on Monday - Yea!!
Old 10-24-2003, 09:19 AM
Bill
airbill337's Avatar
My high beams and blue light is also constently on. How can I switch to low beams. The relay is working fine. I don't know if I am suppose to pull back the lever or not, I've tried that and it will not move back or forth, just up and down for the turn signals. Is it suppose to go back and forth or not?
Bill K.
72 914/4 Project car
98 Ford Ranger
Old 11-23-2003, 11:28 PM
M. Hendrix's Avatar
Yes, the stem is supposed to toggle.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 11-24-2003, 03:27 AM
Bill
airbill337's Avatar
The reason I was asking this is, the original and the 2 I got from the boneyard will not toggle. Is there something I'm not seeing?
Bill K.
98 Ford Ranger
Old 11-24-2003, 04:14 AM
M. Hendrix's Avatar
Sorry, I can't be of anymore help at the moment, it's been 15 years since I've been in that part of the car.
M
Old 11-24-2003, 06:03 AM
Conrad W Peden's Avatar
I had the same problem with the high beams and it turned out to be the fuses.
Old fuses and corrosion led to poor operation.
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 11-24-2003, 03:29 PM
Toast's Avatar
My high beams are always on!
73 Yellow 2.0
86 Toyota 4X4
Old 11-25-2003, 07:30 AM
914 Geek
Somebody really oughtta spank you for that one, Toast!
I volunteer.
--DD
Old 11-25-2003, 09:49 AM
