Question Rust under rocker
I took off the rocker panel and this is what I found! How serious does this appear to be compared to others you all have seen?
Old 11-02-2003, 05:37 PM
thesey914's Avatar
Ouch! The pic nearer the door hinge is not structural, the other area is where the jack plate was.....914s all tend to get some rot in the jack plate but yours has rotted right through. If these areas have rotted there's a good chance that there is a lot of rot lurking elsewhere too. Good news is repair panels are available for all the bits you've posted.
Old 11-03-2003, 12:25 AM
Conrad W Peden's Avatar
I had very similar rust to yours and ened up with this....
The car was a free 73 2.0 so I could justify doing the work.
Worse case scenario, good luck.
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 11-03-2003, 05:16 PM
Jim Smolka's Avatar
Be carefull doing a bunch of welding, the car can shrink, making it difficult to open/close the doors. Braces may be installed to keep the door gaps correct.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 11-03-2003, 06:20 PM
After cutting and before welding the body guy braced it.
Diagonals from side to side and across the doors.
Old 11-04-2003, 01:15 PM
grind weld build
sean_V8_914's Avatar
install the targa top, open the door, stand on the longitudinal and jump up and down. observe top gap movement. If teh rust has structurally compromised the car, the top will move. If teh car is solid, it will not. I htink you should be at least 160 lbs to perform this test. dont be afraid to jump hard.
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 11-04-2003, 05:17 PM
The longitudinal being the piece running side to side just in fron of the seats??
Old 11-04-2003, 05:24 PM
grind weld build
no. the longitudinal runs length-wise, under teh door opening. The test is to observe chassis flex along the side of teh car. Do the passenger's side first.
73 Orange, CS #601
Trek 6500+
Sean M!
Old 11-04-2003, 09:01 PM
