Va914's Avatar
Quick Q
How bright is the alternator and oil pressure light when the key is turned to on? (not started)
Cheers
Kerry
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 11-05-2003, 03:59 PM
Usually pretty bright - just like any other car.
If your light is dim, it could be the same problem that I am having with my high beam indicator (which is really dim). I beleive this is caused by dirt or something blocking the light path becuse the acthal bulb burns bright.
Old 11-05-2003, 04:39 PM
Va914's Avatar
Pulled the bulb socket out and the bulb is VERY dim with the key in the on position.
My charging system has been not right latley. I was hopping the bulb was causing the problems.
Kerry
914-6 in the Werks
Old 11-05-2003, 05:18 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
my oil pressure light is bright with the key on and the engine not running. once it starts, the light is sometimes dim and sometimes goes out completely. hopefully, someone will tell me the pressure switch is bad or the ground is dirty. i figured that since it is not as bright when running, the pressure is up/ok. sure hope i figured right. need to install that VDO pressure gauge.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 11-05-2003, 06:01 PM
My high beam indicator didn't work, yet the bulb lit up. As I was working on the tach anyway I found the blue plastic film they used to color the light had turned completely black and blocked the light. The green turn signal was still OK. I replaced it with blue plastic I cut from a file folder tab now it's good as new. Maybe the same thing happens to the other lights.
Old 11-05-2003, 07:47 PM
Toast's Avatar
It depends of if your stepping on the accelerator pedal and how much. It flickers at idle.
Oh wait, not started right? Ummmm, looks medium-well.
73 Yellow 2.0
86 Toyota 4X4
Old 11-05-2003, 11:44 PM
914 Geek
Clean up the connections on the bulb, on the socket (if any), and on the wires. Clean the grounds as well. Clean up fuse #8 or #9, or just replace it because they're cheap. Clean the "fingers" that hold the fuse as well.
Contact cleaner (like Radio Shack TV Tuner Cleaner or Wurth Contact OL) is your friend here.
If it were just the alternator light that were dim, I'd suggest replacing it. But if both are dim, then I'd say you have bad connections somewhere. Check the ground path for the bulbs; I think it may be through the body of the gauge.
--DD
Old 11-06-2003, 09:19 AM
Va914's Avatar
Thanks guys..
Dave, the low fuel and gauge lights work fine. I just have trouble with the Alt and oil lights.
I was thinking the oil gauge problem is coming from the seatbelt relay. I messed around with the relays and removed all relays from under the seat. Connected the yellow wires and was done. I may have borke the green/red wire along the way??
The alt light is dim all of the time. It doesn't get brighter or dimmer. With the key in the on position it is just as dim as when it is running.
I'll pick-up some cleaner and clean the contacts. I haven't checked the voltage at the dash lights. Should the red/white wire have a full12v.
Cheers
Kerry
914-6 in the Werks
Old 11-06-2003, 09:38 AM
