grind weld build
20-foot Picasso
I just painted my 20-foot car. Now its a 3 foot car (depending on your vision prescription). Engine building, brakes, and suspension.... piece o cake. Painting.... should be called preping and cleaning. This project suffered major feature creep. I was just going to mask it and spray it, ya know, just make it shine a little. The paint was only $100. Then I pulled the trunk seal out. Who wants to go through the hassle of masking all that rubber? Under the trunk seal I found rust in the rail, not a lot but I ground it off and treated it with POR-15. Then I went to tape the door seals off. The seals already had red over-spray from their previous life in the donor car I took them from so I pulled those too…Damn! More rust. Not a lot, so I scraped, brushed and more POR-15. I see a pattern developing here so I just pulled it all apart. Removed all the seals, the interior, lights, signals, even the windshield. So here it is, 4 weeks and $300 later. I photographed every step of the way . If ya’ll are interested, I’ll re-size the pics and post some
flesh heals, memories last forever! 73 Orange, CS #601 73 Rayco V8 glug, glug 69 911 w/82 turbo look on 275 35 18s (for sale) Trek 6500+ Sean M! |
grind weld build
I like this pic
grind weld build
how did teh ash get under teh seal?
Wow Sean, that looks great!
Jeff Keyzer 72 914 w/2056 built by Mark DeBernardi @ Original Customs Megasquirt with MSII upgrade |
Nice work...Looks like a good paint job from here...
Enjoy your newly painted 914
Kerry (Back on the road, sort of) 914-6 in the Werks |
Nice job Sean! I am interested in seeing your pics of the process. What equipment and paint type did you use?
Chris H. '75 914 3.3 |
Very nice....! Looks good with the matching rockers too.
For some reason I thought you had a V8.. ?!
Jason (AZ914) 75 Malaga Red 914/6 3.2 |
Looks like it was worth the effort! Good Job!
I'm gonna do the same someday. |
grind weld build
Die grinder, wire wheel on a drill, an entire gallon of Acrylic Enamel with MAR Hyde wet look hardener, anti-fish eye drops in mix, POR-15/grey, MAR Hyde etching primer over POR-15, Laquer high built Evercoat primer everywhere else. Carboduim sand paper (one sheet lasts a long time) A gallon of wax/grease removing solvent
grind weld build
V8 car is next. this is my daily driver car
grind weld build
...the white one is the daily driver.
grind weld build
grind weld build
grey POR 15 on the windshield frame's surface rust. Etching primer near all teh edges. I like clean sharp edge lines. cowl line was fun to shape. wiper shaft recess holds water. What was DR P thinking when they designed this into the car? I also droped the ventilation fan box as not to paint the leaf screen white. I like the look of teh black screen under the white painted ventilation intake grill
grind weld build
grind weld build
pile o' 914 nuggets
grind weld build
don't be scared, take that rocker panel off and look. WOW, am I lucky! Battery tray center was 1/2 gone but frome under tray was OK. I POR 15'd it all. POR-15 says it is impervious to battery acid. I am currently conducting a test sample cause I dont believe it yet.
grind weld build
dont forget to clean out all those little drain holes! I poked them then blew them out with 125 psi. I also did this 8 years ago when I bought the car
grind weld build
I'll be down in Green valley for xmass
Sean, did you paint that outdoors? If so, before the fires I presume. Looks great!
'75 1.8 -->1911 |
grind weld build
HVLP gun (thanks Scott) in my driveway, . no overspray, 9 am, bugs love the fresh paint, they hovered over it. some landed (wet sandable bugs) I sprayed it one week before teh fires & D&G
