Angry i found under body rust is it bad???
1 longitudinal is ok the other has a bit of rust on it and a small to mid sized hole in the middle of it the floor panels were coated and there are 2 small 1 inch by 1/2 inch holes starting not all that bad
i found a rear floor board for 200 and longitudinals 180 each
1. are these good prices and
2. is it going to cost me a hell of alot of money to get it fixed[IMG]"C:\Documents and Settings\Spec Ops\Desktop\New Folder\6b_3.jpg"[/IMG]
thats the car new paint and new german vinal i got for 3,300
'73 1.7 i guess its a good price but should i sell the car since it has this much rust on it or is it ok and fixable
going to collage soon and got me another car besides this one
Old 11-29-2003, 07:08 PM
Zeke's Avatar
Sounds a bit pricey for the longs, assuming you are talking used. You didn't say. Look at the Pelican sheet metal area and study the 'clamshell.' Might be all you need. It ain't no $180.
Old 11-29-2003, 08:07 PM
914 Geek
Shorty, you gotta hit the "Attach Multiple" button when you post stuff from your hard drive. As is, you simply pointed to something that is still on your hard drive, so none of the rest of us can see it...
--DD
Old 11-29-2003, 09:03 PM
no longs new at performaceproducts.com the
if you look under the car between the jackpoint and rear wheel wall that triangular piece it the longitudinal right?
Blue 73' 914 1.7
Old 11-30-2003, 06:38 AM
clam shell? plus for some odd reason the jack point sticks out half an inch on theleft side
Blue 73' 914 1.7
Old 11-30-2003, 06:47 AM
914 Geek
http://www.pelicanparts.com/catalog/shopcart/9144/por_9144_chasis_main.htm
The longitudinal runs from the rear wheel well all the way to the front wheel well. There are more parts that cover the areas of that assembly that make the turn and head upward toward the rear shock mount. Check the pics on the page linked above (click where it says "pic") to see what parts you may need. Keep in mind that it is very likely that there is more Bad Stuff hiding that you have not found yet.
--DD
Old 11-30-2003, 10:09 AM
so this is normal for 914's? rust problems
(I'm new ... just got my first)
Blue 73' 914 1.7
Old 11-30-2003, 10:42 AM
