Replace 1.8 exhaust with 1.7?
This is my first tech post and I have to say this site is great. You guys have saved me so much time. I hope I can contribute.
I need to replace my ’75 1.8 HE’s due to rot on the shrouds. The PO removed the majority of the emissions stuff and I plan to get rid of the cat (the car is exempt from smog test in MA). With that in mind, should I replace the HE with a pair from a 1.7, as well as the muffler? I know this will involve some heat ducting fabrication and probably the exhaust hanger plate, but other than that, does the header end of the 1.7 HE bolt right to the engine without modification? I’m tempted to go without heat for a season by cutting off the original HE shrouds and modifying the engine side of the headers to direct the exhaust straight back (getting rid of the hairpin bend in the pipes) into the stock exhaust, minus the cat. Any advantage to this or should I just go with the earlier 1.7 design. Any input would be appreciated.
Jim '75 1.8 in pieces 'Happy is the person who is able to discern the causes of things.' Virgil (37 B.C.) |
Your best bet would be the system from a '73-'74 2.0L as the pipes are bigger and better flowing.
That said the earlier 1.7/1.8 systems are better than what you have. To convert(1.7/1.8 style): Early support bracket Heat exchangers Muffler of some type New exhaust gaskets New exhaust nuts And I believe you would need the remainder of the heat system tin (elbows, connector pipes, etc) if you wanted heat. To convert to the 2.0 Style: Late support bracket Heat exchangers Muffler New exhaust gaskets New exhaust nuts And what was mentioned All of this will bolt right up to your Teener. Most of what was mentioned is available used from us Teener freaks. Ya just need to ask. Some of us may even have the SS shrouded heat exchanges too (shameless plug huh)!
Ron Meier Backyard Shadetree Mechanic 1974 914/6 conversion with 2.7L (The Grey Ghost) 1973 Chalon with 2.4T MFI (Schlitzalom) All my 4 cylinders are gone
914 Geek
Go with the 1.7 or early 2.0 setup. The cat is not that huge a constriction in the flow; the tight 180-degree bends and massively unequal lengths of the piping are more to blame IMHO.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thanks guys. I'll scrap the stock HEs and mufflers and seek some early model stuff. Scrappy,
Oops, must have hit enter by mistake,
anyway, Scrappy, I'll look you up and post when I am ready to buy, maybe you will still have what I need. Meanwhile, I'm in the throws of a longitudinal rebuild from Rest Design which has put me on a limited budget for the next few weeks. Thanks again
i'm right in the middle of doing this. i'm going with the ss 2.0. you will also need the lower tin that attaches to the h.e.'s and the bottom of the engine. the 2.0 style gives you more options with regards to the muffler.
kevin 914club member
here? not so much i think. high five!!! |
