Heat flapper box
Is there difference between the right and left flapper box on the exhaust system? And if so what is really the diffrence?
Jeff Margush
914 1.8
1981 242 Volvo Turbo
Old 01-21-2004, 03:21 AM
ruddyboys's Avatar
There is a difference. The control arm for each need to be facing each other inboard so the cable can connect correctly.
74 LE "Bumblebee"
03 Jetta Wagon
Old 01-21-2004, 04:08 AM
914 Geek
The control arms rotate--it's not so they face inboard, it's so the control arm on the flapper comes out of the top or the bottom of the valve.
A curious thing--on my car, the cables are the wrong length if you use one left valve and one right valve. There were two right-side (?? left side??) valves on it when I bought the car, and that's the way the cables fit the best. So I have one control arm coming out the top of the valve, and one coming out the bottom.
--DD
Old 01-21-2004, 08:36 AM
Interesting what you said Dave cause I appear to have two of the same side flapper boxes, cause one arm is on top the other on bottom so I guess next step is to run the cables and see it it will hook up ok.
Jeff Margush
914 1.8
Old 01-21-2004, 11:13 AM
mike_the_man's Avatar
I have two of the same side flappers also. Won one on ebay, and they sent the wrong one. I was to lazy to complain, so I just flipped it. If the cable doesn't fit, I used a brake cable from a tandem bike, from my local bike shop. Was longer than I needed, so I just snipped the end. Cheap and easy solution.
Mike
74 914 2.0L
78 VW Gti
82 VW Rabbit
Old 01-21-2004, 12:48 PM
