yousaidpoo's Avatar
Send a message via AIM to yousaidpoo
suspension
i'm looking to autocross my 1.8 and i was wondering if anybody had suggestions for suspension all the way around. i was looking at koni yellows (adjusting the shocks by turning a know is good), and was wondering if anybody had any experience with these shocks, or if they know of another easily adjustable shock that would suit my needs
thanks
"Real racers turn right too."
"When life goes flying by... Downshift."
Old 03-12-2004, 01:54 PM
yousaidpoo's Avatar
my other question is basically what should be done to the front suspension to help. suspension isnt one of my more knowledgable subjects
Old 03-12-2004, 01:59 PM
Jim Smolka's Avatar
Ok, How much do you have to spend?
List of Upgrades
1. New Ball joints
2. Turbo Tie Rod Ends.
3. Replace bushing with bearings
4. Replace struts with coil overs (requires strenthening the car)
5. Add Sway bar
6. Increase size of T-Bar
7. Upgrade to 911 5 lug front end
8. Replace steel cross beam with Alum cross beam
9. Corner balance the car
10. Install mono-balls at the top of the strut.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-12-2004, 04:44 PM
914 Geek
Step 0: RTFR. Read The Rulebook. When building a "race car", this should always always always be the first thing you do.
My own autoX preferences have already been spelled out in a previous thread. The short version is, get the car into good working order, take all the junk out of the trunks and cockpit, over-fill by a half-quart of oil, and GO!! Worry about suspension modifications later, drive first.
As you can see, it's really easy to spend a boat-load of money on suspension mods if you feel the need. I don't think it's necessary, as a bone-stock 914 will provide you with a truly absurd amount of fun as-is!
--DD
Old 03-12-2004, 07:45 PM
grind weld build
sean_V8_914's Avatar
this topic seems popular lately. there are many good threads about this topic. uise teh search button on this BBS
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 03-12-2004, 08:35 PM
Biggy72's Avatar
I've heard koni yellows are good because of teh versatility. You can set it to ride soft of harsh depending on what your needs are and I think most koni products are pretty high quality.
Black 72 1.7 914
http://www.pelicanparts.com/gallery/Biggy72/
WSU Formula SAE
Drivetrain team leader/ Suspension team
http://www.mme.wsu.edu/~sae/
Old 03-12-2004, 11:46 PM
Jim Smolka's Avatar
The Koni shocks as they come out of the box only control the rebound. They can be revalved and made to control the compression and rebound. A bunch of folks also like the Bilstein sport shocks.
'81 SC 3.6 (Beast)
Old 03-13-2004, 02:43 AM
