Downshift Problem
Finally ventured out on the freeways yesterday. What a blast!
Car (74 2.0) shifts up through all gears great, but I'm having a problem coming back down - especially downshifting from 4th to 3rd. Can't seem to get to 2nd or 3rd very easily after being in 4th/5th- I keep catching 4th & 5th again. After about ten tries, it eventually goes into second. Also, it doesn't do this every time, just most of the time. Sometimes there's no problem.
Is it me? I checked the archives but didn't see this problem specifically. Is there a technique I should use or might it be an adjustment? Thanks!
SD
Steve/San Diego
'74 2.0L Ragtop
http://www.pelicanparts.com/pmpre/images/stevedee/Porsche_914_Ragtop.jpg
Old 04-05-2004, 10:31 AM
John Rogers's Avatar
I say to check the slop in the shifter bushings, make sure both set screws are tight, check for torn/broken motor mounts and worn shifter parts. Doesn't have to be in that order, but any combination of those can cause erratic shifting. Good luck
Old 04-05-2004, 11:06 AM
914 Geek
Agreed. Much of that stuff can be found in the Tech Articles section, under "Shifting Improvements".
--DD
Old 04-05-2004, 01:53 PM
Thanks, Dave (and John) - I will look at the bushings (hopefully) this weekend. Great article, BTW.
I have found that when in 4th, if I want to downshift to 3rd, all I need to do is push the gearshift all the way to the left against the 1st/R spring, then come back out to the middle, 3rd/2nd engages with no problem.
Steve/San Diego
'74 2.0L Ragtop
Old 04-07-2004, 09:08 AM
