Porsche Crest 74' 1.8 Starting Problem
So I take the car out this afternoon, and it cranked for a longer period of time than usual before starting. Drove it for 30 minutes or so, let it sit for maybe 30 minutes or so, and when I try to start it to go home, it just keeps cranking. I had to turn the key a good 7 or 8 times before the thing sputtered a couple times, and then finally started after a couple more tries. Uneventful trip home for another 30 minutes, and it started right up when I gave it another try in the garage.
Similar situations have happened before, but it has never taken this long to start.
Funny thing is, there's no pattern, as I started it on Thursday for the first time in a week and it started immediately.
Before I put it away for the winter, I replaced the fuel pump (which has been relocated to the front trunk). I did use Stabil before putting it away for the winter.
Does this sound like anything, or is just part of owning a 30 year old car? Please help.
Steve Bomeli
74' 2.0
Old 04-10-2004, 03:05 PM
Kenny Powell's Avatar
Re: 74' 1.8 Starting Problem
[QUOTE][i]Originally posted by srb7f [/i
You may have just dislodged contamination into the fuel system?......also check for vacuum leaks the Ljet system has to be virtually vaccuum leak free to even start! check your oil cap gasket&"O" ring... scan all connections!
75' 2.0 w Ljet
"I like the way she doesn't move in the curve's... and then she let's go!"
Old 04-10-2004, 04:35 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
kenny, can you comment on your 2.0 L-jet system, please. 912E brain? fuel injector #'s?
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 04-10-2004, 05:48 PM
bump
Steve Bomeli
74' 2.0
Old 04-11-2004, 07:56 PM
grind weld build
sean_V8_914's Avatar
check THE double relay that lives under teh battery tray. My 74 1.8 had a similar problem due to intermittent contacts there
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 04-12-2004, 07:43 PM
