914 engine
just bought what I thought was a 914 engine. The serial # is GA007519, seller says that this is a 74 2.0, does the serial # look correct?
Thanks in advance.
Old 04-25-2004, 12:56 PM
Banned
Alfred1's Avatar
North American '73 and '74, 914 2.0L engine numbers begin with GA.
Old 04-25-2004, 01:48 PM
Joe Sharp's Avatar
My 74 2L says GA010928.
Joe
http://www.clubnarp.com/
My mechanical ability seems to be directly related to my ability to withstand pain.
He who plays with the most toys wins.
Old 04-25-2004, 02:50 PM
RETIRED
Joe Bob's Avatar
Look at the heads....if they have three bolts attaching the intake runners to the heads it's most likely a REAL 2.0.
2012 ML350 3.0 Turbo Diesel
Old 04-25-2004, 06:35 PM
I took a look, there are four bolts.
Old 04-26-2004, 04:18 PM
RETIRED
Joe Bob's Avatar
Heads could have been replaced or it could be a bus motor....
Old 04-26-2004, 04:58 PM
tat2dphreak's Avatar
it's a 2.0 case... if it says GA anyway...
the bus 2.0s started with other letter combos:
http://tunacan.net/t4/reference/case.htm
could have easily just had the heads replaced with 1.8 heads... pray they weren't replaced with late BUS heads (square port)
'72, now with a living, breathing 2056...
Old 04-26-2004, 06:55 PM
lmcchesney's Avatar
What is the specific difference between Bus heads and 914 heads other than the square vs oval exhaust port?
Valves, Porting, Flows, spark plug angle, combuation chamber?
L. McC
Old 04-27-2004, 03:45 AM
Everything.... All of the above. What the hell, thought you knew these things!
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 04-27-2004, 04:17 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Ignoring the later "square port" Bus heads...
The 2.0 bus heads are about the worst-performing Type IV heads out there. The valves are either as small as or smaller than the 1.7 valves. The intake and exhaust ports are both fairly small. Those result in them flowing significantly worse than the 2.0 914 heads. The combustion chamber is shaped differently than the 914 heads. The plug is in a different location.
You can start with Bus heads and have them re-worked until they perform as well as or better than stock 914 heads, but that requires some know-how and some machine tools. And that's where people like Jake, and Adrian at Headflow Masters, and others come in.
--DD
Old 04-27-2004, 09:10 AM
lmcchesney's Avatar
Thanks all.
Jake, is dad progressing?
Haven't heard.
L. McC
Old 04-27-2004, 09:58 AM
