Send a message via Yahoo to 72_914
Converting to FI , fuel line questions
I am converting from dual Dell's to FI. I bought the motor complete with the FI (73 1.7L) but I have a few questions about how the fuel lines hook up. First, I bought a fuel pump and need to know which fuel lines runs to them and where do I hook them up. The pump has three hose fittings coming out of the top with the letters S, D & R by them. There are two lines coming from the tank, where do I hook them up to? Second, the fuel lines going to the injectors are all un-hooked. Is there a diagram on how these hook up on pelican parts? If not could someone explain or send me a picture?
Thanks,
James
jamesadrienne@aol.com
Old 04-19-2000, 08:59 PM
Send a message via AIM to JP Noonan
This should do ya. Dave Darlings 2.0L vac diagram is really close to the 1.7L *in theory anyway) for a 1.7L specific diagram look in the Haynes manual.
http://www.914fan.net/techref.html
I STRONGLY recomend you replace the center tunnel lines and put the pump up front.
http://www.pelicanparts.com/techarticles/914_gas_lines/914_replace_gas_lines.htm
Old 04-19-2000, 09:58 PM
914 Geek
There is a newer version of the diagram available on the Pelican Parts page.
http://www.pelicanparts.com/914/technical_specs/914_20FI_diag.htm
There is also a diagram from an early 1.7, which doesn't have all of the equipment that the 73 system would have.
http://www.pelicanparts.com/914/technical_specs/914_17FI_diag.htm
Between the two, you should be able to figure out where everything goes.
--DD
Old 04-20-2000, 06:53 AM
