CHT calibration?
Hey all,
Does anyone happen to have a temp vs. resistance curve for the factory head temp sensor? Now that I'm leaving the factory FI behind, it'd be a shame for such a well positioned diagnostic sensor to go to waste. -Josh2 |
Look on my D-Jet parts web page, there's a link to a chart that shows the temp vs. resistance curve. I also have some of my own data on the page, too.
914 Geek
Just remember that the stock sensor's location makes it fairly slow to respond... Raby can bend your ear for a while with why you don't want to use that spot for your CHT gauge sender.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I already have a VDO CHT sensor (the flat thermocouple under the spark plug), but it'd be nice to have a secondary sensor that I can use as well without needing to spend the $50 or whatever to get another flat sensor setup.
There's a BIG difference in the temps read by the two sensors, however. Something on the order of 200dF.
You can get another ring thermocouple from Aircooled.net for $15. With a DPDT switch, you could easily set it up so the one gauge reads one sender or the other. The gauge is the expensive bit, not the sender. |
Hmm, not a bad idea. I knew that the factory CHT wouldn't agree with the VDO unit, but the switch idea is a good one. It'd be nice to be able to monitor -both- heads, without needing an additional gauge.
-Josh2 |
