Roll pin for pedal cluster
Where can I buy a new roll pin for my rebuilt pedal cluster???
Thanks, Mike |
Try your local Ace Hardware. They have a kit with all sizes of rollpins.
914 Geek
Get the expensive multi-layered one. I believe we can supply you with a stock one--I forget the part number but it's in the Porsche parts book.
The commonly-available roll pins are not strong enough. You need one that has several "wraps" at least. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
mikey,
if you get the rebuild kit from our host it will have one in it, but read this .the pin in the kit is a "spiral pin" or i've heard them called a triple rolled, roll pin, this is what you want. i rebuilt mine with the kit about a year or so ago and have had no problems. doug
doug waters 70 914-6 dougwatersfotos.com http://www.flickr.com/photos/dougwatersfotos/ |
914 Geek
The pin that comes in the bronze bushing kit is, umm... apparently under-engineered for the job. It's the standard one-layer pin, and I feel it should not be used. The stock part is much beefier, and is of the multiple-layer type. Sorry I wasn't more clear about that.
--DD
Well......see, I was given the bronze bushing kit from a friend, but I don't have the roll pin. So Dave....can I buy one from Pelican, and if so, how much is it??
Mike |
914 Geek
Yes, you can get the stock pin. I don't know how much it is; I'm not tied into the sales end of the house. Jason or John (chibone_914) would be able to help you on that--email them or just call 888-280-7799 during working hours.
--DD
The Village Idiot says, "We can still get the correct roll pin" part number 900-309-002-00, a whopping .75 cents.....
Thank you! John johnechi@hotmail.com |
Local Porsche dealer... $0.83. Porsche part
Qarl |
doug
Be sure to thank The Village Idiot for me please!!!! Thank you.
Mike |
My 914 parts catalog has a different p/n for the roll pin 999.095.003.00
Is the 900.309.002.00 the 911 p/n? (basically the same part?) Ralph 74 2.0 |
canna change law physics
Yeah, I was going to say that the correct pin is under a buck. I think it is the same pin used in the tranny. It is best to used the proper one. I used an understrenth one, once...(pointing finger) ONCE!
James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
