Swaybar Bushing install
Are there any tricks to installing the nylon bushings used on the stock rear sway bars on a 76. At first glance it looks like an impossible fit. I verified that the parts I recieved form Pelican are the same size as the reminants I pulled out of the dogbone. Thanks in advance
Bill
Old 08-08-2004, 05:03 AM
place them in some HOT water for a minute or 2 to soften them up a bit and quickly push them in. a bit of grease on the hole of the drop links helps too. remember the open portions face opposite directions. they are a super tight fit. the hot water trick is great for firewall bushings too.
kevin
here? not so much i think. high five!!!
Old 08-08-2004, 07:44 AM
