Question Front calipers
What's the difference, if any, between the right and left front caliper? Just bought a pair of rebuilt ones but they are not labelled right or left. I see most places show diferent part numbers for each side. What's the diff? They look the same to me. ?????
Old 04-06-2007, 07:01 PM
914 Geek
The bleeder valve should be on top. (This won't help on a caliper that has two bleeders, though!) There is also a "cutout" on the caliper piston which faces a specific direction. I believe it is upward and forward in both cases. Check Haynes or your Factory manual to see where the "brake pad shim" goes; the cutout in the piston mates with the edges of the shim.
--DD
Old 04-06-2007, 07:59 PM
djpateman's Avatar
Dave is correct, the anti-rotation device hangs from the upper pin. With the later dual bleed screws, the caliper can be converted to the opposite side by rotating the pistons correctly.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-06-2007, 08:17 PM
Checked caliper piston for the "cutout". It is there but not in the correct position. Calipers did not have anti-roatation clip when I took the old ones off. How important is this clip? Can you drive w/o it? Calipers are new. DId not want to take apart to rotate piston around. My guess is the piston has to be completely removed to get it into the correct position. Done that before it's not fun.
Old 04-07-2007, 05:37 AM
djpateman's Avatar
Well, you can Mickey Mouse it, but then it is not a proper job done is it. If the caliper has been properly rebuilt it should not be hard to rotate the pistons. At least with my rebuilds it isn't.
Addicted since 1975
Old 04-07-2007, 06:17 PM
