F1BADUDE's Avatar
5 lug conversion
I'm reading the 5 lug conversion tech article and am planning on drilling front rotors. Article shows drilling our 4 lug rotors. From what I can tell, a 914/6 rotor is vented where the 914/4 is not. PP also only has crossdrilled rotors for 914/6 and I would like crossdrilled at least on the front.
Has anyone drilled out a 914/6 rotor to fit 914/4 hub?
Is the rotor the same diameter?
Also, do you think I should find older rear hubs with bosses as my car is a 75.
Thanks,
Old 08-14-2004, 03:33 PM
mike95125's Avatar
For indepth explanations, do a search. But, the short is that you can drill the rears on your car and should have no problem even though they lack the extra bosses (I have this, no problems). Drilling the front, I don't know. On the 914club.com web site Mike Mueller has fabricated a five lug front hub that fits on to the stock /4 front spindles.
HTH
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 08-15-2004, 01:20 PM
Acox914's Avatar
Send a message via AIM to Acox914
cant use vented rotors with stock 914 front calipers. (vented vs nonvented)
-Aaron
"60% of the time, it works every time"
Old 08-15-2004, 02:06 PM
F1BADUDE's Avatar
Was planning on converting to 320i calipers. Do you know if vented will work with BMW?
Old 08-15-2004, 05:13 PM
Acox914's Avatar
thats a negative.. bmw work with non vented
-Aaron
Old 08-15-2004, 08:05 PM
Scott S's Avatar
The hub assembly is vastly different from a 4 bolt to a 5 bolt. You can have someone like troutman drill and stud virgin front rotors to a five bolt pattern. Aslo, it seems to be the consensus that drilling front rotors for "venting" does nothing but give you less braking surface and cause cracking the holes.
There are tons of discussions on both topics.
- A pile of British stuff
- A growing pile of German stuff
... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....)
Old 08-16-2004, 07:53 AM
cruiksdr's Avatar
It's probably easier and cheaper and definately safer to upgrade to 911 struts/hubs/rotors/calipers. They are out there for fairly little $$ and are direct bolt ins. This gives you a stronger front end, vented rotors, and slightly larger braking surface without sacrificing strength. I don't know about you, but I don't my front end blowing apart at 90mph! I got a complete front and rear set of brakes struts from a 73 911 T for $400. Very easy conversion (including the 911 ebrake). I then got the larger BMW front calipers for another $200 w/new high performance pads. It's a great set up. Plus, when it's time to replace rotors, there's no modification needed. Just get the 911s and you're good to go. Think about it.
'73 914-6 3.0SC
'69 Jaguar XKE
'05 Colorado Crew Cab
Old 08-22-2004, 09:16 PM
F1BADUDE's Avatar
Will the 911 trailing arms bolt up to 914 as well?
What year range of 911 parts should I be looking for?
Thanks,
Old 08-30-2004, 06:37 PM
Acox914's Avatar
no. you use 914 rear arms, 914 parts; the hub redrilled for 5 lug or 911 (69 - 73) hubs and stub axles inside a 914 rear arm.
do a search here and on 914club.com and there is lots of info :0
-Aaron
Old 08-30-2004, 06:45 PM
silver2.0's Avatar
Stupid question- Why does everyone convert to a 5 lug? I can understand if you want to use special wheels for monster brakes, but if you are just using 320i brakes like me, on a 4 stud, what's the big deal? Is it so you can run better quality wheels? I know you can put more power to a 5 lug, but there is no way on earth you will shear 4 lugs with less than 250 lb ft of torque. (from my experience). Thanks for humoring my newbie question.
Old 08-30-2004, 07:37 PM
cruiksdr's Avatar
Yes, definately the 914 trailing arms. Most use redrilled 914 hubs, but 914/6 hubs are stronger. I'm not sure about the 911 rear hub/stub axle. the 911 hub will not work with a 914 stub axle (different splines). I had a 911 hub/stub axle set from a 73 911T, and the stub axle was too large to fit in the rear trailing arm. I don't know about earlier 911s but 73 and up will definately not work. I ended up redrilling my rear hubs, and that seemed to work fine.
From what I understand, for the front end, you can use struts, etc. from a 911 right up to at least 1986 or so. It's a straight bolt up opperation. You keep your A arms and just swap out the struts/brakes. It's pretty easy. What year/model you choose depends more on how much you want to spend and how much brake you want. The front end from an 80s 911 carerra will give you awsome brakes but will cost a bit more than earlier. For the rear end, as mentioned, keep the 914 stuff, drill the hubs, and if you want vented rears, get 911 rotors and M callipers. This is how I set up the 911 e brake since the 911 caliper does not have that built in like the 914. If you don't want/need vented rears, keep the 914 calipers and use 911 rotors
'73 914-6 3.0SC
'69 Jaguar XKE
Old 08-30-2004, 08:14 PM
F1BADUDE's Avatar
In my case ,originally, I wanted larger DIA & width 911 Fuchs to fill out my GT flares.
I later decided to do race build though and now. So as well as more braking surface, I would also need the extra beef
Here's my GT-5S plans:
16 X 8 5 lug Fuchs (new repros) 225/50 Yokohama A032R FRT
16 X 9 5 lug Fuchs (new repros) 246/45 Yokohama A032R RR
2.2L 6 (tearing down now)
46 X 40 ported heads drilled for twin plug (on the way from CA)
Tec 3R controled EFI (still figuring out what I'll do for TBs)
Tec 3R twin plug crank fire
11:1 compression Forged pistons
GE-80 cams
I would estimate about 210 ft/lbs of torque @ 5700rpm
Old 08-30-2004, 08:15 PM
cruiksdr's Avatar
Many convert to the 5 lug so they can have a better choice of rims and can go with bigger/better brakes. The 320 set up is supposed to be pretty good, but you don't get vented rotors which does affect braking perfomance (fade). Also, the added strength is a must if you have a six (although I've heard a number of people say that the 4 lug can handle plenty of torgue. Who knows I opted for the 911 hardware because it allowed me to more or less replicate the 914-6 and stick with all porsche parts. I was mostly after the brake upgrade, and also I wanted to beef up the strenght since I do have a six. Oh, and it looks really cool
'73 914-6 3.0SC
'69 Jaguar XKE
Old 08-30-2004, 08:23 PM
F1BADUDE's Avatar
A 914/6 and a 1.8T
Your all right
Old 08-30-2004, 08:40 PM
F1BADUDE's Avatar
Do 914/6 axles have different spline?
Old 08-30-2004, 09:25 PM
Acox914's Avatar
they do (pretty sure)
-Aaron
Old 08-30-2004, 09:55 PM
F1BADUDE's Avatar
they do
Are they the same as 911?
Seems like I saw rebuilt 914/6 axels at PP, AA or somewhere.
Old 08-30-2004, 10:19 PM
Acox914's Avatar
i believe they are
-Aaron
Old 08-30-2004, 10:25 PM
cruiksdr's Avatar
As far as I know, they are the same as the 911s but have a smaller diameter for the half shaft to fit in the rear trailing arm. They show up on ebay peridically, too. They tend to be pretty expensive.
'73 914-6 3.0SC
'69 Jaguar XKE
Old 08-31-2004, 06:44 AM
Acox914's Avatar
cheapest way is use 914 stub axles, and redrilled 914 hubs
-Aaron
Old 08-31-2004, 08:21 AM
