Picture of Fuse box??? Help=
Is their anyone out their who can pull their Fuse box down and take a picture of the back, i have a wire thats just chillin. Not connected to anything. If someone could get me a picture i could locate where it goes. I woudl really appreciate this. Thank you
-selling Porsche 914 - Ask
Old 09-20-2004, 06:06 PM
elwood-914's Avatar
Color of wire??
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 09-20-2004, 06:48 PM
elwood-914's Avatar
Oh yeah, what year?
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 09-20-2004, 06:49 PM
Its a black wire, just hanging off coming from somewhere near the middle (to the right looking forward)
Thansk for help
Old 09-20-2004, 06:51 PM
elwood-914's Avatar
I see a black wire with a white stripe....... on my 73'
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 09-20-2004, 07:00 PM
Hmm
Do you know where it goes to (ex. lights? )?
Old 09-20-2004, 07:26 PM
elwood-914's Avatar
O.K. Took the fuse panel down. I have 2 black wires(no stripes), both are terminated to 1 connector and that connector is termated on the 4th terminal from the right, on the fuse panel.(sitting in the car) It is the terminal closest to the driver (closest side of fuse)
Hope this helps.
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 09-20-2004, 07:37 PM
John Rogers's Avatar
Probably it is/was for something that is no longer used or is not working? There are several switched 12 fused connections such as the one mentioned by elwood-914 which is used a lot. You might want to look up under the dash to see if there is a crimped ended wire that is just sitting there or one with tape on one end? Also is there any tape residue or solder on the end of the wire that is hanging as that can give you a clue as to what it connected to under the dash. Good luck
Old 09-20-2004, 09:56 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
my recommendation is to compare your connections to the schematic. somewhere on one of the BBS's, maybe this one, there is a color schematic. with a 30+ year old car, you never know what the PO (s) did and it would be worthwhile to verify wiring connections....
oh...
http://www.pelicanparts.com/914/914_electrical_diagrams.htm
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 09-21-2004, 06:14 AM
When i get home ill try to check out where the wire is coming from and try some suggestions. Thanks for the replies
Old 09-21-2004, 09:29 AM
