Other cars with same front struts?
Does anyone know if other cars share the same front struts as a 914? Low budget junkyard dog. (Pete) Thanks
Old 09-20-2004, 06:44 AM
914 Geek
VW 411 and 412. Good luck in finding those in junkyards... Make sure you get the ones with the same sort of ball-joint retaining method as your current ones--the later ones use a wedge pin, the earlier ones a straight pin or bolt.
The 911 struts do bolt in, but you have to go with the 911 brakes and the five-lug wheels in the front. Five-lug front and four-lug rear looks really cheesy....
--DD
Old 09-20-2004, 10:29 AM
Are you sure Dave ? would'nt a 914 front hub, with the 4 bolt pattern fit onto a 911 front strut ?
Michel Richard
Old 09-20-2004, 09:25 PM
mike mueller's Avatar
nope, different size wheel bearings..the 911 strut uses bigger bearings than the 914 hubs
'73 914, 1.7, with Boxster transmission in the future?
Old 09-20-2004, 11:02 PM
mike95125's Avatar
what about 944 stuff?
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 09-20-2004, 11:12 PM
914 Geek
Nope. The struts are, I believe, not interchangeable with 911 or 914.
--DD
Old 09-20-2004, 11:14 PM
AZ914's Avatar
Pete,
I have some front struts/dischubs/calipers collecting dust in my garage. If you are shopping for some... send me a note.
Jason (AZ914)
75 Malaga Red 914/6 3.2
Old 09-21-2004, 11:19 AM
If you want to refresh yours for less $$, Gabriel makes gas cartidges for the 914... mine are awaiting installation.
2005 BMW 530i
2008 GMC Acadia
Old 09-23-2004, 05:11 PM
mike95125's Avatar
I fished some gabriels out of a 911, they were leaking bad, but they looked like they fit. I wish I knew how they performed before they suffered shuch a horrible death. I use KB. Cheap and good enough.
-74 BMW R90
Old 09-23-2004, 11:16 PM
I read on this site once that the Gabriels are real bad.
Old 09-27-2004, 07:12 PM
I bought KYB's from Pelican for mine. EASY to change.
Old 09-29-2004, 06:59 AM
