lawrencedesigns's Avatar
How to remove the danged starter switch
Ok...Confused again. I used Pelicans faq to remove my starter switch. When I got to the last step...My system does not have the "two screws that hold in the small housing piece that constrains the ignition switch."
So I have pulled the entire mechanism out. Now what am I missing? Why can't I get the switch out? The housing won't come apart...
Keeth Lawrence
76 914 project
84 Alfa Romeo Spyder
Old 10-30-2004, 09:26 AM
I don't know anything about the 75-76 models, but is there a hole in the side to push in a release pin while turning the ignition key? Or maybe those slots along each side of the key bezel are used for releasing the mechanism? Just guessing here until someone who actually knows posts the instructions.
Old 10-30-2004, 07:34 PM
mike95125's Avatar
Put your key in and turn it. It is currently locked to the shaft. You must have the key to get it out easily. The two screws that were mentioned in the other tech article were for a /6 or 911 probably as they are put in with two screws to the dash. Also, you wont be able to get the collar off without the ig switch removed.
HTH
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 10-30-2004, 09:05 PM
914 Geek
I believe the article was written specifically about 72-74 cars. The 75-76 ignition lock, as pictured here, is different. I think I recall reading that you actually have to drill a hole in the housing to access the pin that you depress to remove the lock cylinder.
Ick.
I think forum user "ejm914" had posted the info on how to do that, but I cannot find it in a search.
--DD
Old 10-31-2004, 02:07 PM
