914 with 2.4 engine
I was looking at a early 914 in very nice condition. The owner had taken the 1.7 and "bored" it to a 2.4. The car ran and drove very nicely, but I was wondering if there are any tolerance issues or reliability issues with this type of "enhancement". (1.7 to 2.4)
Must be a 78x103 motor which uses steel cylinders. They tend to warp after 30k miles and start to leak oil.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
Find out what crank was used and what rods were used when it was assembled. If it is what is known as a "short rod" motor then the rods can break at high RPMs (6k or so). If it was a forged crank and after market forged rods then it should be strong. Also ask if it has a cam with type 1 lifters as that is done sometimes when building hotrodded engines. Good luck
Thanks John and Bleyseng I will and report back.
78X103 would be a 2.6 liter.
http://www.pelicanparts.com/gallery/skline It's easier to get forgiveness than it is to get permission. 75 Slantnose V8 03 S-10 Extended cab stepside in Yellow 72 914 Parts car |
try a 76 crank
-Aaron "60% of the time, it works every time" |
Actually, cast iron 103s are lucky to see past a dyno session or 10,000 miles without a head leak starting!
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
