webcam 86a
Does this cam run head temps cooler than stock fi cam? Does it have longer exhaust duration?? What do you guys think of this cam in general?
Mike |
anyone????
Administrator
Have you checked the specs on http://www.webcamshafts.com ? The 86a is, as I recall, a very agressive grind that trades low-end torque for high-RPM power. It has more duration in both intake and exhaust, significant overlap, and lots of lift. You will need to rev the motor high enough that upgrading the valve train (specifically the springs) is necessary, plus you'll want higher compression than stock because it will "leak out" during the overlap when both intake and exhaust valves are open.
I don't know about the head temps. The cam will absolutely not work with the stock-type fuel injection (D-jet or L-jet). --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Would an 86 web be better??? I am building a 2056, with stock 71mm crank, stock 2 liter heads. About where does the power band kick in with an 86a????
Mike |
Administrator
Not sure where the power band kicks in. The 86 is supposed to be milder and an "all-around street cam", presumably meaning that it doesn't give up much low-end and doesn't require you to wind the motor up to 7K.
--DD
I trust you will be running carbs, so my suggestion would be to run the 86b cam with at least a set of 40 IDF, 44's would be better. You will not be dissapointed in the performance.
http://www.pelicanparts.com/gallery/skline It's easier to get forgiveness than it is to get permission. 75 Slantnose V8 03 S-10 Extended cab stepside in Yellow 72 914 Parts car |
Member w/ Title Problems
I'd personally run a 163/86b. 10:1 CR, stock valve sizes. Should rip @ss, and that's really the point. Also, the 163/86b cam runs split duration, which will help head temps to at least some degree.
Jason Porter - 888-280-7799 ext 233 - jason@pelicanparts.com 1989 Chevy Silverado 3500 - 454TBI, 4x4, 8 gallons/mile |
I've been running a 1.8L engine with an 86a for 3 years now in my F Prod car.
The cam would be great for an aggressive street engine. You don't need big valves or dual springs to make it work. HD springs are a must though, as the powerband is from 4500-6500 rpm. The valve lift is .435" which is a bit more than stock and you might need to clearance the pistons depending on the CR. It will work with unmodified heads but if you let it breath the engine really comes alive. I have chassis dyno results that show about 125 RWHP with stock size SS valves, ported, 11.5:1 CR, modified 40IDF carbs, etc.
Chris Foley CFR-Tangerine Racing Products, LLC - 914 Products and Services |
