Question Engine Bar - From tail to side shift
I'm in the process of switching a 1.7L out of my '71 and putting in a 1975 2.0L with side shift trans.
I have the engine bar that came with the 2.0 mounted on the engine because of course I need it for the shift bar hole.
My problem/question is I'm wandering if the mounting of the bar to the body of the car was different in later year cars. The front of the engine is about an inch low and the tin doesn't line up. The bolt also ends up short.
I also have the plate that goes between the bar and the mounting.
What am I missing?
Sean
Old 02-10-2005, 06:31 PM
seanery's Avatar
I've never done it myself, so I'm guessing, but from your pic it looks like you can adjust the car mount a bit...maybe adjust it on both sides of the car to make it fit?
Old 02-10-2005, 06:58 PM
Acox914's Avatar
Send a message via AIM to Acox914
late cars have solid mount son the outside.... you need one of those......
early cars had the rubber mounts there.....
-Aaron
"60% of the time, it works every time"
Old 02-10-2005, 07:00 PM
SirAndy's Avatar
i agree, you need to get rid of those outer rubber mounts and get the solid mounts for the sideshifter bar.
the sideshifter has rubber mounts on the engine itself, the early tailshifter did not.
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 02-10-2005, 07:05 PM
Ok thanks guys.
I kind of suspected there was a different mount.
Hope I can do this without having to move the engine too much.
Sean
Old 02-10-2005, 07:08 PM
ejm914's Avatar
The mounts you need are little more than a 4-5" long "U" shaped piece with three bolt holes. It drops into the bracket on the body from above and the engine mount bar bolts up to it.
Have you got all the other pieces you'll need? shifter, shift rod, firewall bushing....
Old 02-10-2005, 07:14 PM
Yes, everything else has been changed over. I don't remember these mounts being mentioned in any of the conversion threads or tech article, though it wouldnt surprise me (or my wife) if I missed it.
Bummer is that pic was just taken tonight, the engine sitting on the transmission jack almost in. This stopped me.
Hopefully one of the 3 parts cars down the road has these mounts still and I can do a morning raid.
Old 02-10-2005, 07:22 PM
I'm also doing this conversion and have run into the same problem. Where can I get these solid mounts? Pelican had no idea.
Old 02-28-2005, 05:58 PM
914 Geek
Feh! They're in the parts book and the PET. Someone was not looking carefully enough! Tell whomever it was that you want the brackets for the outboard end of the 73+ motor mount bar. I seem to remember that the bolts are a different length as well (shorter, I believe) so you might pick up a pair of them at the same time. There are also specific washers, which are just regular round washers with the edges trimmed down on opposite sides so they look more like ovals. I've sent out part numbers before, but don't have access to them right now.
Then again, you can find some beefy U-channel and cut and drill it appropriately if you're motivated... And if you want to take responsibility for the mounting yourself.
--DD
Old 03-01-2005, 10:43 AM
Thanks Dave, I'll try again.
Old 03-01-2005, 12:53 PM
