914 Air Conditioning
Ok, the new car has air. It looks like all that is missing is the compressor. I think these had VPD and DPD A/C units. How do I figure out what compressor I need? Can I convert this to 134a?
Basically every question you would expect!
Thanks,
Matt
Old 02-15-2005, 08:06 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
lot more work needs to be done that just adding a compressor.
If you have a 1.7 or a 1.8 just dont bother.. The motors just arent powerful enough to really work a A/C system effectively.
Keep in mind that you will need to replace the hoses to the front as the original hoses are, at the youngest, 29 years old. They are also of the old style barrier design which allowed R-12 to slowly leak out to help control system pressures. This will be a custom fabrication. You'll also need to get a R-134a compatible reciever-drier and also have the condensor in the front trunk pressure tested and flushed. Even then it isnt going to get enough airflow from under the car to work that well, so you'll have to come up with something different.
Then there's the unit under the dash. You'll have to disassemble it, replace all the seals, then try to figure out a way to make the evaporator more effective.
You then need to adress the compressor. If yous car has the extra pulley shim, you're in luck, this will allow you to run the belt to the compressor. If you dont have it, you'll have to fab something to drive it off the cooling fan. You'll also have to rig up a step-up switch for the idle to raise it as the compressor kicks on. You also have to figure out a way to mount the new compressor. Don't bother dealing with Griffiths either.... Jerk
In the end you'll be left with an A/C system that wont cool as well as an old R-12 system, and it will suck down the power of your engine. Unless you have a six and lots of money to spend, just take the roof off... The whole thing is basically going to be a custome fabrication. Keep in mind that no 914 ever left the factory with A/C, and the systems were installed (rather poorly) by VW and Porsche/Audi dealers.
My 2 cents
Old 02-15-2005, 10:47 PM
COLDBASS's Avatar
Try these guys for a compressor, shine the old York line and go with a newer style rotary vance type, less draw on motor.
http://www.compressor-intl.com/aboutus/index.htm
2 years ago, Shad Laws did a series of articles on this subject in VW trends. You may wish to reasearch.
Some years ago, BA posted the figures/comparisson on HP strain.
IIRC the York was 6+, and nippon or seiko was 1 or 2...(its been a few years/beers since I read the article).
If you dont have the pulley set up to drive the compressor take a look under my user name in the 912 section. You may be able to fab a similar pulley as mine...
Good Luck
923/912E (2.1l OEM EFI
'99 F150 4x4 Chipped (who cares)
LLVL in the LBC...
"Long Hoods Rule"
"RICE - The Breakfast of Champions"
Old 02-16-2005, 07:13 AM
