Send a message via AIM to AlexO
D-Jet help: FI trigger points
My injectors don't fire while cranking. They will fire when I sweep the TPS, so I know that the injectors and grounds are good. I have checked continuity across the points, they seem to be ok. The only strange thing I have found is on the plug that goes to the FI points, there is a 5v signal on on of the side terminals, shouldn't the voltage be on the center one? I can't tell for sure looking at the diagrams....
--Alex
-'74 2.0
Old 08-26-2000, 08:57 AM
Just checked continuity from the plug to the ECU according to the PP diagram, and its all good.
--Alex
Old 08-26-2000, 10:12 AM
