"Plumbing" for heat exchangers
My 1974 2.0 has an electric blower in the engine compartment with one tube connected to the driver J tube. The passenger J tube has a cap on it above the engine tin. The blower has only one outlet. Didn't the 914 blow heat in both sides? I realize air came in from the crank driven fan, and the electric was a "booster".
My car is reasonbly un-molested, but I am not clear on this aspect.
Jeannie - Wonderful Wife
1974 914 2nd owner@52000 mi
2002 Jeep Wrangler Sport
2003 Toyota Sequoia
Golden Retriever - Heidi
Old 03-27-2005, 10:09 AM
WOODPIE's Avatar
I could very well be wrong on this, but I think only one year's production, the 73's, were equipped with a splitter at the booster fan, with hose feeding to both sides. There are parts available of course, to convert the one sided set-up to dual.
Ed
Old 03-27-2005, 11:21 AM
If you want to convert to having the blower split between both sides, it can be done with parts found locally for maybe $35 total. E-mail sbomeli@virginia.edu if you have further questions or want pictures of the setup I just did on my car. Steve
Steve Bomeli
74' 2.0
Old 03-27-2005, 02:52 PM
914 Geek
The 70-72 cars had a fan that had two outlets. They changed to a single-outlet fan for the 73 model year, and ran the hose to only the driver's side heat exchanger. For the 75-76 model years, they put a splitter on the fan's outlet, and ran hoses to both exchangers again. So the 73-74 model year cars were the ones that had a capped-off J-tube on the right side exchanger.
You can fake up a splitter or Y from PVC plumbing parts if you are at all motivated. There are also other ways to go; some of the late-style fans had a detachable splitter and you can swap that over to your fan. Or you can just get the late-style fan.
--DD
Old 03-27-2005, 03:51 PM
Bowman74's Avatar
--DD
Dave,
My '74 has two hoses instead of one, maybe that was a mid '74 change? Of course that doesn't mean that a PO hadn't made that modification and it came from the factory with only one...
Thanks,
Kevin
Old 03-29-2005, 01:11 PM
Bowman 74, can you post a picture?
2003 Toyota Sequoia
Old 03-29-2005, 02:23 PM
Bowman74's Avatar
I'll look at snapping one tonight. Basically the fan has a single outlet with a Y splitter and then two hoses coming off of it. It is the same part shown here on the PP catalog: http://www.pelicanparts.com/catalog/images/exhaust/914_blower_motor_hose.JPG
Thanks,
Kevin
Old 03-30-2005, 06:08 AM
ruddyboys's Avatar
Kevin, That is the set up from the 75-76, some one added that. to your 74. Also on the 70-72 the blower was mounted in the center over the impeller, and on the 73-76 it was mounted on the left hand side of the engine bay.
74 LE "Bumblebee"
03 Jetta Wagon
Old 03-31-2005, 04:14 AM
Bowman74's Avatar
Well good news for me then!
Thanks,
Kevin
Old 03-31-2005, 05:21 AM
