R32 Pilot's Avatar
Setting ECU idle Mixture
I need to set the ECU idle mixture since I did a bunch of work (replacing seals, gasjkets, hoses etc... ) I also have a new MPS.
The car idles like crap! Hunts surges, etc.... I would like to check the idle mixture setting because I think it is pretty rich.
Based on what I've read, the procedure is to get the car thoroughly warmed up and then set the mixture with a %CO monitor and adjust the idle screw (iterative process I'm sure!).
I would like to do this myself and was looking at the gunson tester in order to set the mixture. I know they are finicky but I think it would work.
However, I have been itching to buy a wideband O2 sensor for tuning my other car. So my question is can I use the O2 sensor (with the tailpipe fixture for the O2)?
There is a chart that seems to relate %CO to an A/F ratio (14.1 seems to ring a bell for 3%CO). Will this setup get me where I want to go??? DO I need to disconnect the smog pump or does the 3% CO numbner take the extra air into account.
Thanks in advance for your help.
Old 03-30-2005, 04:53 PM
914 Geek
The 3% number does not take EGR, supplementary air (from the smog pump), or catalytic converter action into account. You are supposed to bypass all of those emissions-control devices. I don't know what AFR it compares to, but I would think that setting your idle up for stoich (14.7:1) or a bit on the rich side (14:1) would be more than good enough.
--DD
Old 03-30-2005, 06:08 PM
Banned
Alfred1's Avatar
Do you have the Haynes manual? If not, here's some info from the manual on how to adjust the idle speed and CO plus a couple links to information on the proper range for air/fuel ratios.
Haynes
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=LGU0016&cartid=
http://www.widebandcommander.com/faq.htm#2
Old 03-30-2005, 07:50 PM
pbanders's Avatar
Send a message via Yahoo to pbanders
I recommend you go to a mechanic with a shop-quality emissions analyzer and do your idle mixture adjustment setting there, with the engine FULLY warmed up. Bring along your Gunston or other meter to cross-calibrate if you want.
Old 03-31-2005, 08:34 AM
Banned
Alfred1's Avatar
Actually, the best thing to do would be to put your car on a dyno so that you can check the air/fuel mixture throughout the entire rev range when there's a load on the motor. Here's a graph (wheel hp) of a stock 2.0L.
Old 03-31-2005, 09:56 AM
Not right in the head
nutzforporsche's Avatar
Send a message via Yahoo to nutzforporsche
I'm doing the same thing on mine right now. I have a Gunson tester and it works great, I set my idle at 3% and that is perfect. Non-load at 3k dropped it down to the 1.5 percentile area. I was told by one of the guys on the 914club site that under load I should be in the 4% area. This is fine for me.
stevethacker@earthlink.net
87' 944S
99' BMW 740iL
Old 04-06-2005, 05:56 AM
