Send a message via AIM to Jake Seidel Send a message via Yahoo to Jake Seidel
Porsche Crest Trainsmisson oil
I Need help on how to drain and fill my transmission oil. Please help me out thanks.
Jake seidel
72 1.7 914
90 Honda Accord
91 Honda Accord
95 BMW 540i FS
Old 04-10-2005, 02:26 PM
Banned
Alfred1's Avatar
You need a 17mm Hex Key and then some kind of hand pump to pump the new fluid in.
Old 04-10-2005, 03:01 PM
Acox914's Avatar
Send a message via AIM to Acox914
no silly handpump needed!
buy the 80/90 weight gear oil in the 1 quart pointy containers.... plenty of room to maneuver the container up there....
pull the fill plug. fill with fluid until it tries to come out the fill hole
-Aaron
"60% of the time, it works every time"
Old 04-10-2005, 04:59 PM
I Need to know where the fill plug is and drain plug. Is the one above the bottom plug on the right side of the transmission the fill one and the bottom one the drain plug?
Jake seidel
72 1.7 914
90 Honda Accord
91 Honda Accord
95 BMW 540i FS
Old 04-10-2005, 05:06 PM
Both plugs look identical. The drain plug is on the very bottom of the transmission. The fill plug is on side of the transmission (the passenger side about a 3rd of the way towards the back of the trans and about 1/2 the way up).
Both plugs require a 17mm allen wrench (hex). You can also get 17mm hex socket to fit your ratchet. You can get these at sears or the local car parts shop.
ALWAYS remove the "fill" plug first. This is so that if you accidently strip it, you won't be stuck with a transmission that has already been drained of oil.
I have found that it's easiest if you use a pipe or something to add leverage to the hex. This reduces the chance of you stripping the plug. The plugs are usually in pretty tight - resist tapping the wrench with a hammer, there pretty soft metal and strip easily.
You don't have to have a pump to fill the transmission (although that does make it easier). If you buy the oil that has a pointed spout, there is just enough room to tip the bottle sideways and fill the transmission.
You fill the transmission until oil starts to come out of the fill hole (i.e., it's full).
When you do the project, check to see if your drain plug is magnetic. If it's not, you can buy magnetic plugs at Pelican for a few bucks and that will help catch any stray metal shavings. If your plugs are slightly stripped already, I would replace with new ones at this time.
Vern
Old 04-10-2005, 08:42 PM
914 Geek
I feel that the hand pump makes the job much easier. Besides, I have the gallon bottle of Swepco and it doesn't maneuver very gracefully.... You can get the pumps (I have one for quart bottles that was called a "Marine Flush Kit", and one for gallon bottles but I don't remember what it was called) at your Friendly Local Auto Parts Store (FLAPS) for just a handfull of bucks apiece. Pays for itself about the second time you use it, IMHO.
--DD
Old 04-11-2005, 11:37 AM
