Red face new engine troubles - HOT HOT HOT
so heres an annoying story. i got a new motor built for my 914.....
its a 2.0l with 96mm pistons (keith black), fully balanced and polished, twin 40mm dellorttos, gas flowed, non standard cam, crane x700 electronic ignition, head work also done....
when i firstgot the car back it ran ok for the first 400 or so miles as i took it easy on the engine, but as soon as i did my oil change and set the valves and pushed it anywhere past 3500 revs it got a little hot, like about 200º...
hmm, so i checked everything.... tinware is intact, all seals in place, flaps operating correctly, nothing stuck in the fan, so i guessed it was the nature of the beast and so proceeded to fit the external oil cooler system as explained in the tech articles.
this worked fine...... till i went to a track day, spun off, cracked the cooler, lost all my oil on the way home and fried the motor. aaaarrrrrgggghhhh.
so after a lengthy rebuild the motor is back in the car.... and guess what... as soon as i get over 3500 revs the temp is climbing again....
what can it be? anyone got any ideas?
martin
Old 06-13-2005, 04:08 AM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
From my conversations with Jake, the exhaust duration on the cam if its close to stock will keep the oil temps at around 200-220 degrees. That is ok.
Have you checked the A/F ratios? Could be running lean.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 06-13-2005, 06:53 AM
i always thought the temp should be 180?
the cam is farfromstock however,,, durations im not sure about.
if 200-220 is ok for temp then im fine. can anyone confirm this?
Old 06-13-2005, 08:45 AM
914 Geek
212 degrees F is a great temperature for oil. That will boil the water out of the oil, and it is the temperature used for most oil tests (viscocity, etc.).
Some like 180F, but I feel 180F is a minimum for regular operating temperature.
Anything below about 220F is just fine. Over 240F is generally considered a real cause for worry...
--DD
Old 06-13-2005, 11:09 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I agree with Dave here.. 200 degrees is fine.. You really should have nothing to worry about.. If you add an external cooler, you'll drop temps about 20-30 degrees, but I dont think you need to
My SC would get to 250 degrees in traffic before i added the external cooler. Now it never gets over 200 degrees
Old 06-13-2005, 12:41 PM
wow. i always thought oil kinda 'broke' and needs to be replaced after getting to 200.....
so i guess my next question is.....
what kinda oil should i put in the motor? people have so many different opinions.
thanks,
martin
Old 06-13-2005, 01:34 PM
Castrol 20/50 GTX is what i run
Old 06-13-2005, 01:59 PM
914 Geek
I personally have been using Kendall GT-1 20/50; there is a good chance that I will move to a diesel-oriented oil after I use up my current case. (I am spacing on the name, but it's popular with the big-rig crowd. And recommended by a highly reputable local mechanic.)
Frankly, just about any name brand oil should be good enough--provided you change it very regularly.
--DD
Old 06-13-2005, 04:52 PM
