Question How to remove A/C equip?
I have a '74, 2.0 with dealer-installed A/C unit that I want to remove. Is there a tech article out there on how to do this? Any "tricks of the trade" or advice to make it easier? (Appears to me that I have to remove the A/C compressor in order to replace the oil cooler seals!) As always, everyone's help to this novice is appreciated!
Old 06-17-2005, 07:20 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
not aware of any tech article on A/C removal. it's probably obvious to remove all screws and connections. EPA would probably like you to evacuate the freon, if any, still in the system. when replacing the oil cooler seals, you don't completely remove the oil cooler but instead, move the cooler to provide clearance to replace the seals. i think there is no way to completely remove the cooler with the engine still in the car. that said, i don't know how the compressor affects seal replacement. BTW, welcome to the east coast and consider yourself invited to the 2nd mid-atlantic mid-engined ramble in mid sept. search 914club for kerry914 who will be hosting the gathering.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 06-17-2005, 07:43 AM
Eric 914's Avatar
I might be interested in your under dash unit. Let me know before you toss it out, we should be able to work something out.
Eric
'75 914 Renegaded 327 SBC
Old 06-17-2005, 09:18 AM
Va914's Avatar
Yes welcome
If you up to a drive bring you car up to my place and I will remove the stuff
I installed the A/C into mine and know how to remove the parts. If you get a patch panel for the front trunk (where teh condenser is) I can weld that in too..
E-mail me and we can set up a time
Cheers
Kerry
kerrys914@yahoo.com
Kerry (Back on the road, sort of)
914-6 in the Werks
Old 06-19-2005, 07:04 AM
i would not mind helping to remove the system, i can even come to you as i am in baltimore. i am looking to have the under dash unit for a future install. as for the floor section in the front trunk they can be found even locally, there was a 914 in the crazy rays in jessup that had a ok front trunk floor
where are you in the dc/baltimore area
scott thacher
75 914 with 2.5 l 98 suby engine on the road
Old 06-19-2005, 10:48 PM
