Rear Trailing Arm - Stiffening
I was just wondering......
Although I have never raced my car and I probably won't (at least not anytime soon), would there be any benefit to the boxed stiffening kits being installed.
I'm asking because I am currently replacing the rear bushings and I'm going to bead blast the rear trailing arms and either paint or powder coat. I figured that while I have the suspension removed from the car, maybe I would install one of these kits before painting.
Just a thought and any tips would be appreciated.
Old 07-18-2005, 03:16 PM
philinjax's Avatar
Boxed trailing arms are like tits on a boar hog, worthless. The stock trailing arm is a strong and rigid piece. Unless you slam sideways into a curb at significant speed, they will retain their shape, boxing the arms will not help in this case. A much more significant concern would be the integrety of the arm to chassis mounting, much more suseptable to distortion than the trailing arms, as such.
Phil
Old 07-18-2005, 05:41 PM
SirAndy's Avatar
if you hit something hard enough to bend the trailing arm, guess what happens when you have a boxed trailing arm?
you'll be bending the chassis instead ...
what's it gonna be? a new set of trailing arms or a full day of setup and another day of stretching on a celette bench?
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 07-21-2005, 04:57 PM
