heat exchangers help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
okay i am stumped ... i just received a ss heat exchanger and it does not fit
![]() the exshaust tubes look like they will fit but the air part is way short ( about 1 foot ) meaning the flapper box and the air inlet are too far back .... am i just missing a part or two and if i am does any body have any for sale ------------------ scott thacher 75 1.8 under construction 75 under rust (fine german rust) |
Scott, there is a extension tube that goes from the HE to the flapper box. It's about 1 foot long. I found mine on a car in the junk yard when I switched over the SS HE. Also you probably need the vertical tubes too that go to the heater blower hoses.
Geoff ------------------ 76 914 2.0L |
i have a complete heat exchanger now i quess i can steal parts from it but nothing looks like it lines up
i will go look again i just learned the smiles so i will be playing ------------------ scott thacher 75 1.8 under construction 75 under rust (fine german rust) |
Scott, look at the diagram at
http://www.pelicanparts.com/914/parts/engine/exhaust_system_small.htm and the part is number 13. That is the tube you are looking for. Geoff ![]() ------------------ 76 914 2.0L |
actally i need the warm air guide too (part 19) and the elbow for the driver side if any body has one for sale ... the heat exchangers i have now dont need the elbow and air guide there are all one piece, also my exchangers only have one outlet to the muffler so now i have to get a muffler too
![]() ------------------ scott thacher 75 1.8 under construction 75 under rust (fine german rust) |
Administrator
The difference is that the SS exchangers are the early style exhaust, and your 75 exhaust is the late style one.
Doe the exchangers have a "kick up" near the end, or are they flat all the way back to the muffler flange? If they are flat, you have 2.0 exchangers. You'll need a 2.0 muffler.. If they kick up, you have a 1.7/1.8 set, and you'll need a 1.7 or 1.8 muffler. I don't know if the 75-76 muffler hanger will work with the early style 2.0 exhaust, or with the early-style 1.7/1.8 exhaust, or with neither one. You may or may not need to buy a muffler hanger. Give yours a try, bolt up the exchangers and then hang the muffler hanger on the tranny. See if the holes/notches in the bottom of the hanger line up with the holes in the muffler flange. If not, you'll have to buy a new hanger. --DD |
