heat exchangers help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
okay i am stumped ... i just received a ss heat exchanger and it does not fit
the exshaust tubes look like they will fit but the air part is way short ( about 1 foot ) meaning the flapper box and the air inlet are too far back .... am i just missing a part or two and if i am does any body have any for sale
scott thacher
75 1.8 under construction
75 under rust
(fine german rust)
Old 03-01-2001, 02:19 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
Scott, there is a extension tube that goes from the HE to the flapper box. It's about 1 foot long. I found mine on a car in the junk yard when I switched over the SS HE. Also you probably need the vertical tubes too that go to the heater blower hoses.
Geoff
76 914 2.0L
Old 03-01-2001, 03:23 PM
i have a complete heat exchanger now i quess i can steal parts from it but nothing looks like it lines up
i will go look again
i just learned the smiles so i will be playing
scott thacher
75 under rust
(fine german rust)
Old 03-01-2001, 03:39 PM
Bleyseng's Avatar
Scott, look at the diagram at
http://www.pelicanparts.com/914/parts/engine/exhaust_system_small.htm and the part is number 13. That is the tube you are looking for.
Geoff
76 914 2.0L
Old 03-01-2001, 05:06 PM
actally i need the warm air guide too (part 19) and the elbow for the driver side if any body has one for sale ... the heat exchangers i have now dont need the elbow and air guide there are all one piece, also my exchangers only have one outlet to the muffler so now i have to get a muffler too
scott thacher
75 under rust
(fine german rust)
Old 03-01-2001, 06:30 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The difference is that the SS exchangers are the early style exhaust, and your 75 exhaust is the late style one.
Doe the exchangers have a "kick up" near the end, or are they flat all the way back to the muffler flange? If they are flat, you have 2.0 exchangers. You'll need a 2.0 muffler.. If they kick up, you have a 1.7/1.8 set, and you'll need a 1.7 or 1.8 muffler.
I don't know if the 75-76 muffler hanger will work with the early style 2.0 exhaust, or with the early-style 1.7/1.8 exhaust, or with neither one. You may or may not need to buy a muffler hanger. Give yours a try, bolt up the exchangers and then hang the muffler hanger on the tranny. See if the holes/notches in the bottom of the hanger line up with the holes in the muffler flange. If not, you'll have to buy a new hanger.
--DD
Old 03-01-2001, 09:31 PM
