uhhh
pull a door lock out and take it to a locksmith
Bunch of old cars
RETIRED
Assuming they are keyed alike....
Got AAA? They will send out a locksmith.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Hey! Nice Rack! "Celette"
Early Alien Sightings 914-M28/11 5.0 Hybrid (The Alien Sharkster) I think I smell your blood in the water WCC 04 done by the kids Who says Aliens only abduct people. |
if you don't have aaa. just call a mobile locksmith. they will come to your car, "read" the ignition switch, and cut you a new key. it should run around $80 or so. or...take the steering wheel and related items off, remove the switch, drive to the locksmith, prob leave the switch, drive back to retrieve it, and then put everything back together. after the dust settles you aren't going to save much money, and waste alot of time.
k
here? not so much i think. high five!!! |
You can take the bottom of the steering column apart pretty easy to get to the actual switch. Once you get to the switch you can turn it with a flat blade srewdriver. I've had to do it several times.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
